Author Topic: PBT keycaps  (Read 7605 times)
Offline BlackDragonTribal
  • BDT
Offline Razor Lotus
Re: PBT keycaps
« Reply #1 on: Fri, 16 May 2014, 12:41:31 »
Seems like it's in stock to me
  • BDT
Re: PBT keycaps
« Reply #2 on: Fri, 16 May 2014, 12:46:38 »
What does the mean? I don't understand  :eek:
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
Re: PBT keycaps
« Reply #3 on: Fri, 16 May 2014, 13:12:20 »
The links you included in your original post show that they are in stock. Simply add them to your cart and check out if you want to buy them.
Offline Razor Lotus
Re: PBT keycaps
« Reply #4 on: Fri, 16 May 2014, 13:17:38 »
Yes, it is in stock
  • BDT
Re: PBT keycaps
« Reply #5 on: Fri, 16 May 2014, 13:25:27 »
Yeah thanks all
