Author Topic: 10-keyless with Browns?  (Read 1914 times)
Offline Epic0range
« on: Fri, 16 May 2014, 20:50:39 »
Any recommendations? I'd like something quieter and shorter than i have now.
Back lit if possible I type in low light a lot and am not the best typist.
[sigpic][/sigpic]
KBC Poker w/ PBT
Offline fishfalcon
Re: 10-keyless with Browns?
« Reply #1 on: Fri, 16 May 2014, 20:59:12 »
given that mx brown tkl boards are not hard to find, why not tell us your budget first ;)
WASD Code TKL (MX Greens) | Model M Industrial
Offline Epic0range
« Reply #2 on: Fri, 16 May 2014, 21:23:35 »
For a good board? I have no problem spending what I need to.
[sigpic][/sigpic]
KBC Poker w/ PBT
Offline anoxy
  • Deal with it
« Reply #3 on: Fri, 16 May 2014, 21:46:03 »
This is Geekhack, "spending what I need to" on keyboards is going to vary greatly from person to person. Better to give us a rough limit on what you want to spend.
Like fishfalcon said, TKL with browns is fairly common.
Offline Epic0range
« Reply #4 on: Fri, 16 May 2014, 21:52:33 »
OK, how about, under 300us.
[sigpic][/sigpic]
KBC Poker w/ PBT
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #5 on: Fri, 16 May 2014, 21:57:44 »
TOPRE ALWAYS
Filco
Leopold
Oh backlit...
Ducky
Offline James35
« Reply #6 on: Fri, 16 May 2014, 22:03:20 »
My favorite is the CM Quick Fire Rapid I (white backlighting).
A close 2nd is the Ducky Shine 3 TKL (various color backlighting).
« Last Edit: Sun, 25 May 2014, 18:53:21 by James35 »
Offline Epic0range
« Reply #7 on: Fri, 16 May 2014, 22:06:18 »
I can't find any 10-keyless Ducky.
[sigpic][/sigpic]
KBC Poker w/ PBT
Offline James35
« Last Edit: Fri, 16 May 2014, 22:15:03 by James35 »
Offline Epic0range
« Reply #9 on: Fri, 16 May 2014, 22:14:38 »
Ah *bows* thank you.
[sigpic][/sigpic]
KBC Poker w/ PBT
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #10 on: Fri, 16 May 2014, 22:28:11 »
I'll recommend the ducky as well. Their shine series are awesome !
