Author Topic: Metal Ducky Mini???  (Read 4732 times)
Offline C5Allroad
  • Formerly HUNTERANGEL121
Metal Ducky Mini???
« on: Sat, 17 May 2014, 00:25:30 »
Offline lotus1109
Re: Metal Ducky Mini???
« Reply #1 on: Sat, 17 May 2014, 00:51:03 »
It is a whole new design for ducky but too bad it can't attract me tbh :'(
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #2 on: Sat, 17 May 2014, 00:52:33 »
NOM NOM NOM
Offline Zeal
    • Zeal Generation Inc.
« Reply #3 on: Sat, 17 May 2014, 01:13:27 »
There's already a discussion in the Ducky mini thread.  :)
The case does look like metal, but I have a feeling it's brushed plastic, due to the 3 layer design.
« Reply #4 on: Sat, 17 May 2014, 01:18:23 »
Nice, classy design :)
Offline hehenri
« Reply #5 on: Sat, 17 May 2014, 03:56:32 »
Look pretty steady case, but that design is not for me..
Offline feizor
« Reply #6 on: Sat, 17 May 2014, 04:12:36 »
Looks like the case increases the footprint to 75%
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #7 on: Sat, 17 May 2014, 04:14:07 »
I love the Grey coloured case it gives it a superior style to most 60%ters out there.  Although the best would be always a Korean at over $400USD but very few people would jump on those.
If the price is right on their latest design I think they would shift vast quanities quite easily.  Keeping alive the love of the Cherry-MX for some years to come  :thumb: .
Offline Novus
  • Mondai nothing~
« Reply #8 on: Sat, 17 May 2014, 04:16:57 »
I'd love if they had ducky TKL version.
hehehehehehehe
Offline Oobly
« Reply #9 on: Sat, 17 May 2014, 04:19:32 »
The size of the bezel is a big turn off for me. It negates what I feel is the whole point of going 60%, the size. Fancy-looking, but not my style. I think it would suit a TKL or full size board more.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline qwack
« Reply #10 on: Sat, 17 May 2014, 07:58:25 »
Same here. It may look like metal from afar, but when you look closer it's much more likely to be plastic. Now there are great quality plastics out there, but when they try to pass it off as metal, I find the results underwhelming most of the time.
Pure Pro w/MX Red - [review]
Offline C5Allroad
« Reply #11 on: Sat, 17 May 2014, 12:05:17 »
It could be layers of aluminum...?
Offline Zeal
« Reply #12 on: Sat, 17 May 2014, 12:07:03 »
When's the last time someone made a layered aluminum 60%?
I also don't think Ducky would spend the money on anodizing two different shades of gray.
Offline kohi
« Reply #13 on: Sat, 17 May 2014, 13:31:05 »
is the middle layer just plastic? o:
Offline Zeal
« Reply #14 on: Sat, 17 May 2014, 13:32:39 »
I'm thinking that all 3 layers are plastic. :s Top and bottom being brushed-plastic to look like brushed aluminum.
I just don't see Ducky sandwiching 2 layers of brushed aluminum on plastic. It would require rigorous QC checks to make sure everything is aligned, and there's no excess gaps.
« Reply #15 on: Sat, 17 May 2014, 13:36:23 »
This was already posted a while ago in the Ducky Mini thread..
Already stated that this should be a 60% board with nothing around the damn pcb, this looks GOD AWFUL...
« Reply #16 on: Sat, 17 May 2014, 13:55:59 »
it really is ugly, isn't it
then again, maybe im not one to talk
*looks at QFR*
Offline Zeal
« Reply #17 on: Sat, 17 May 2014, 14:03:33 »
I don't mind the look, personally. It's interesting seeing different stock designs that aren't a tray-style rectangle for 60% boards. Ducky's probably marketing this case as a stylish 60% for users that aren't into $$$ CNC'd aluminum case.
The decline at the bottom is there to rest your thumbs if you have your keyboard close to the edge of your desk. Somewhat works as a wrist rest in a way -- making sure that your actual wrists aren't planted on the table.
Offline Signature
  • master of puppers
  • * Marketplace Moderator
  • snoozing
« Reply #18 on: Sat, 17 May 2014, 14:42:30 »
Dat metal case needs a new design...
« Reply #19 on: Sat, 17 May 2014, 17:53:02 »
Remember that Ducky did make a keyboard recently with an aluminium case top and plastic case bottom.
This might be just one step further.
Offline tbc
« Reply #20 on: Sat, 17 May 2014, 18:42:48 »
it's the same style as the realforce.  which is arguably the BEST plastic case (at least in the front).  i LOVE that aspect of my topre board; it's really great to see that someone willing to use it at least once.
« Last Edit: Sat, 17 May 2014, 20:58:33 by tbc »
Offline Zeal
« Reply #21 on: Sat, 17 May 2014, 18:45:28 »
But screwing in an aluminum case top into a plastic bottom is a lot easier than making sure 2 aluminum layers & 1 plastic sheet is sandwiched properly.
« Reply #22 on: Sat, 17 May 2014, 21:20:34 »
Also why do none of these newer keyboards appear on their web site?
I'm guessing these pictures came from facebook?
Offline Zeal
« Reply #23 on: Sat, 17 May 2014, 22:56:02 »
Correct, sir.  :)
The minis aren't officially released yet, and will be "revealed" at Computex 2014.
Offline C5Allroad
« Reply #24 on: Sun, 18 May 2014, 00:27:24 »
Yep, facebook.....
When the gold version was coming out, was it on Facebook and their site simultaneously? Or facebook and then site?
Offline Zeal
« Reply #25 on: Sun, 18 May 2014, 00:28:13 »
Yep, facebook.....
I'm pretty sure everything gets "previewed" on social media first.
Offline C5Allroad
« Reply #26 on: Sun, 18 May 2014, 00:31:59 »
Yep, facebook.....
I would assume so. Now, if this ducky is hitting the market, we need to get the standard version before this metal one.
