Author Topic: adding machines  (Read 1303 times)
Offline grave00
adding machines
« on: Sat, 17 May 2014, 19:44:27 »
Anyone know of current or obtainable vintage adding machines that use mechanical keys.  I'd be looking for the closest equivalent to a modern tape adding machine.  I've found a couple at thrift stores with decent mechanical switches but too old to have LED readouts.  I think the one I found was a Sharp and the switch if I remember was like an upside down T.
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
Re: adding machines
« Reply #1 on: Mon, 19 May 2014, 16:35:35 »
I saw something really odd on Sunday — like an adding machine, but just number keys. I forget what it was supposed to have done. That one used these switches, which are maybe what you're thinking of:
http://deskthority.net/wiki/Alps_vintage_tee_mount
I don't know any off-hand, but I felt sure that various vintage calculators have shown up with a variety of switches over at Deskthority. Not finding anything at the moment.
The other well-known "T" type is vintage Cherry:
https://plus.google.com/photos/113845661925823397356/albums/5681460096335006737
(I thought HaaTa might have one listed on his Google+ site, but it seems not.)
We're not really sure what those are, as Cherry M5/6/7 etc are really confusing.
Bore Awards
Re: adding machines
« Reply #2 on: Mon, 19 May 2014, 18:03:04 »
Did it have just the ten numbers, or more than that.
If you look at the bud honeywell keypad that HaaTa had a bunch of (and found the spec sheet for!) there are options for numbers only. Then there are Hex entry pads, Telephone exchange dial pads, etc.
There are/were a lot of applications for just numeric entry without operands, though calculators are more common by far.
  • RIP
    • Boring twaddle
Re: adding machines
« Reply #3 on: Mon, 19 May 2014, 18:29:52 »
It was yellow .........................
I don't remember honestly. The numbers, plus a handful of other fairly non-descript keys, in a curved mustard yellow metal case. I forget what it was for now.
Someone somewhere had a whole page of vintage calculators. I don't know that I follow what exactly the OP desires, but this page was fascinating -- the sheer number of PCBs in some of these machines.
Bore Awards
Re: adding machines
« Reply #4 on: Mon, 19 May 2014, 18:54:53 »
