Author Topic: help with mionix keyboard  (Read 1504 times)
Offline keyfetish
« on: Wed, 21 May 2014, 01:20:39 »
hi all. i purchased a mionix keyboard on ebay and i've been typing it for a few days at work. overall, it's a comfortable keyboard to type on. however, i've noticed that the letter O has been acting up, meaning sometimes it would not register at all. what is the main reason that this is happening? and is there a way to remedy the problem?
Offline Pacifist
  • on hiatus
Re: help with mionix keyboard
« Reply #1 on: Wed, 21 May 2014, 01:26:03 »
open it up, and take a picture of the PCB
« Reply #2 on: Wed, 21 May 2014, 01:26:32 »
If it is only one switch, it could be a faulty switch, or bad connections on the PCB.
Given that you bought it from from eBay, it is unlikely to have a warranty?  Unless the seller provides one?
In that case you should be able to remove (desolder) the switch and install a new switch.
« Last Edit: Wed, 21 May 2014, 01:28:10 by rowdy »
Offline keyfetish
« Reply #3 on: Wed, 21 May 2014, 01:33:21 »
i think the seller has tinkered with the keyboard before. i could see scuff mark where the top and bottom keyboard meets like he was trying to pry it open. i will open up the keyboard and take a picture tomorrow. i hope it's an easy fix.
