Author Topic: Question about poker keys  (Read 1851 times)
Offline roaming pear
  • THE Roaming Pear
« on: Wed, 21 May 2014, 22:54:47 »
Hello.... I have a poker 2.. and recently I have seen this picture:
Those yellow keys look really attractive... I want to add them to my keyboard somewhere... I am assuming I'd using 2 of them for FN and PN and maybe one more win.. The 4th won't fit on the esc so I dunno... I am seen some people put all 4 poker keys on the right of the kyeboard..... I'm not sure... but my main issue is that I don't know if these will be at the same height as the rest of my keys. I was told that another set of similar keys had a lower profile so I wanted to know how this one was...
Also are these thick pbt?
Does anyone have any experience with these keys to be able to tell me about that?
Thank you
Does anyone have any accessories or key caps or other poker 2 related things lying around that they are not using?  I don't mind taking it off your hands if you no longer want it...
Offline Pacifist
  • on hiatus
Re: Question about poker keys
« Reply #1 on: Wed, 21 May 2014, 22:56:20 »
Those look like SP's....poker doesn't take 1.5x mods nor 1.75x shift
But haven't seen those yellow ones before, do you have a link to the source?
« Reply #2 on: Wed, 21 May 2014, 23:32:39 »
Most people seem to put the e Poker keys on the 4 bottom right switches, as in: http://geekhack.org/index.php?topic=35152.msg1263513#msg1263513
So I'm guessing they're designed for the bottom row.
And here: http://geekhack.org/index.php?topic=35152.msg1186558#msg1186558
« Last Edit: Wed, 21 May 2014, 23:38:28 by rowdy »
