Author Topic: GMK DOLCH [COMPLETE]  (Read 2354205 times)
Offline lightsout714
Re: GMK DOLCH [taking orders]
« Reply #650 on: Thu, 26 June 2014, 18:12:34 »
hehe, it actually IS expensive, that's a fact. at least by most standards it is. making it look like it's not won't change it.
whether it is WORTH it, that's a whole different story.
Yes no one is denying that GMK full key-set is expensive BUT when you have these installed into your keyboard (whether it be Filco, Leopold, GON, Kmac, etc) you shall see what all the fuss is about.
Very few people ever sell their original GMK keysets in the classifieds unless they jumped on over to the 'darkside (thorpie camp)'.
When you do have authentic Cherry Profile installed into your keyboard there is very little chance for SP to ever get a look-in, into that same keyboard.
i still like my graphite set from SP and i use that over my GMK Classic Beige set.
Shoot that classic  beige this way then!!!    :p
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #651 on: Thu, 26 June 2014, 18:25:02 »
I know classic beige is what I'm waiting for.
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
« Reply #652 on: Thu, 26 June 2014, 18:48:17 »
Me too I'm hoping it comes around again. Happy to get Dolch as well but do want a new complete classic beige one day.
Offline lotus1109
« Reply #653 on: Fri, 27 June 2014, 02:20:10 »
Sad that the gmk dark grey set can't even get this amount of order even though it takes longer to order :(
Offline minho
  • i'm kind of back
« Reply #654 on: Fri, 27 June 2014, 02:36:40 »
Thorpie camp?
Offline Zeal
    • Zeal Generation Inc.
« Reply #655 on: Fri, 27 June 2014, 02:56:50 »
Thorpie camp?
aka Topre master race
Offline maleadt
« Reply #656 on: Fri, 27 June 2014, 04:51:02 »
ordered base + color + space
Offline LechnerDE
« Reply #657 on: Fri, 27 June 2014, 05:12:35 »
First post well spent  :thumb:
Welcome to Geekhack!
« Reply #658 on: Fri, 27 June 2014, 05:50:01 »
I had to wait at least a year before there was anything even remotely Dolch-like to buy :p
Kids got it easy these days :))
Offline maleadt
« Reply #659 on: Fri, 27 June 2014, 06:58:37 »
Thanks for the welcome :) This'll be my first set of custom keycaps, I'm curious to see how they'll go on my Das. I had been looking around for a bit, but having an ISO layout does make it all a bit trickier...
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #660 on: Fri, 27 June 2014, 07:02:06 »
Should have no problem using this set on Das (unless you have the revision with 4 modifiers on the left hand then the spacebar won't fit). ISO is not problem as it is included in the base set.
LEOPOLD owners: I have heard back regarding getting the additional stems on the 6.25 spacebar for Leopold compatibility. Unfortunately at this time GMK is not prepared to offer the tooling change to accommodate this.
« Last Edit: Fri, 27 June 2014, 07:22:05 by IvanIvanovich »
Offline Leska
« Reply #661 on: Fri, 27 June 2014, 09:04:26 »
Im looking forward to my first custom keycaps aswell ! Atm i got a Ducky Pro with PBT keycap ( black ) wich is pretty nice to type on. I have had a Filco Brown, but i honestly like my Ducky alot more. Still wanna try the other blue, white, maybe red MX's.
Already thinking about getting a custom GON made ! They look so freaking awesome.
But we will see. I said to myself, if i get a good chunk of money back from my heat/water bill later this month, im gonna pull the trigger on the GON :)
Offline TBone
« Reply #662 on: Fri, 27 June 2014, 09:06:13 »
Can't resist picking up a base w/ color pack. Are there any examples of what thickness and profile this will look like? Will this be with the same molds original dolch sets were made from? Didn't GMK buy those from Cherry?
EDIT: Nevermind, I looked through the thread and found my answer. So excited!  ;D
« Last Edit: Fri, 27 June 2014, 12:42:13 by TBone »
Offline asgeirtj
« Reply #663 on: Fri, 27 June 2014, 10:45:49 »
What's the reason for getting another spacebar?
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
« Reply #664 on: Fri, 27 June 2014, 10:47:44 »
Yes they are the same as the originals.
Offline LechnerDE
« Reply #665 on: Fri, 27 June 2014, 10:52:03 »
This was discussed earlier in the thread:
http://geekhack.org/index.php?topic=58608.msg1363111#msg1363111
Offline GSimon
« Reply #666 on: Fri, 27 June 2014, 13:36:31 »
Thanks for checking, the existing spacebar on the FC750R is cherry profile(ish) so I can make do.
Offline KatzenKinder
« Reply #667 on: Fri, 27 June 2014, 15:45:15 »
Hey Ivan, just want to make sure my order went through and see if I can tack on another spacebar?
Offline RaVNzCRoFT
  • * Commercial Vendor
« Reply #668 on: Fri, 27 June 2014, 18:04:11 »
Just re-submit your order, it will overwrite your previous one.
<<< Click to view
Offline redeye
« Reply #669 on: Fri, 27 June 2014, 18:11:27 »
really want to add a colour pack to my base order but the base MOQ is so tight, and I dont want the colour pack without the base.
can i add the colour pack and if the worst happens and the base set doesnt happen can i cancel the colour pack?
« Reply #670 on: Fri, 27 June 2014, 18:28:13 »
Pretty sure Ivan said we already hit MOQ with the base set.
Offline GSimon
« Reply #671 on: Fri, 27 June 2014, 18:50:11 »
Yup, it's also indicated as such on the first post of this thread (colored green, for good to go)
Offline redeye
« Reply #672 on: Sat, 28 June 2014, 02:38:54 »
Yep, but we need to factor in cancellations. If we were well into 280's+ I wouldn't be worried.
Is it ok to order both and if the base doesn't make it for whatever reason can I cancel the colour pack?
Offline tmk1207
  • Yêu Màu Tím
    • Vietnam Mechanical Keyboard Club <3
« Reply #673 on: Sat, 28 June 2014, 03:56:26 »
ordered :D
« Reply #674 on: Sat, 28 June 2014, 08:18:55 »
I wouldn't worry about the MOQ and cancellations right now. Just order whatever you like and we will see what is happening around the 15 July when the payment deadline is reached. If there is too many cancellations/non paid orders then we can take steps to try and solve that problem.
Offline LechnerDE
« Reply #675 on: Sat, 28 June 2014, 08:45:09 »
Even if there are cancelations I assume many members (including me) will order a second set to ensure this GB is succesful!
Offline luckyryan333
  • #There'sNoToolForTyping
« Reply #676 on: Sat, 28 June 2014, 11:49:12 »
ordered  :)
No PaiN, No GaiN
How to order from Taobao from outside of China and WITHOUT an Agent
daily driver: C70 w/ Oblivion
on the way: d65_12/gmkblk_3
Offline minho
  • i'm kind of back
« Reply #677 on: Sat, 28 June 2014, 12:11:05 »
Count me in on that! I need my Dolch  :eek:
Offline redeye
« Reply #678 on: Sat, 28 June 2014, 14:03:07 »
Ok thanks guys.
Offline RaVNzCRoFT
« Reply #679 on: Sat, 28 June 2014, 19:13:10 »
Been watching this GB since the very beginning...finally caved and got a base set + extra spacebar.  Wallet hurts a bit, but these keycaps do look great.
<<< Click to view
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #680 on: Sat, 28 June 2014, 21:12:26 »
Count me in on that! I need my Dolch  :o
EVERYBODY needs their Dolch  :thumb: .  Whoever says they don't are deluding themselves to the extreme and need to be put straight onto the path of some true Dolch Enlightenment.
Offline Zeal
« Reply #681 on: Sat, 28 June 2014, 22:10:05 »
Too true. -swims in dolch sets- :cool:
Offline Lurch
« Reply #682 on: Sun, 29 June 2014, 02:51:42 »
#hacked :-X :blank: :thumb:
Quote from: Flyersfan1
Offline DVH
« Reply #683 on: Sun, 29 June 2014, 09:05:51 »
Ordered :p !
Offline Cafiend
Re: GMK DOLCH [orders CLOSE 1 July]
« Reply #684 on: Sun, 29 June 2014, 09:41:39 »
This will be my second set. Wanted to support Ivan's GB and imo it has better options. For my brother's first keyset I'll give him my old set and tell him it's new ..he won't know the difference ;)
Offline Fnzzy
« Reply #685 on: Sun, 29 June 2014, 12:36:30 »
Ordered  :thumb: can't wait!
Offline Hucifer
« Reply #686 on: Sun, 29 June 2014, 12:55:46 »
My first groupbuy and custom caps.
Can't wait to get my hands on these beauties!
              Waiting on / GMK LED Keycaps
Offline CK Briefs
  • formerly calvins1
« Reply #687 on: Sun, 29 June 2014, 12:57:11 »
Too true. -swims in dolch sets- 8)
Yes yes, you'll literally have a pool of dolch; does that mean I get to go to your place to pick my order up?
hehehe
Current Keyboards: Orion - 62g ergo clears;
A87 PS2AVR - 59g ergo clears; QFR - stock blues
Offline Zeal
« Reply #688 on: Sun, 29 June 2014, 13:46:32 »
hehehe
Only if you bring your Orion.  :cool:
« Reply #689 on: Sun, 29 June 2014, 15:58:18 »
I'm starting to get excited! Bout time we pull off a full set GMK buy.
Offline Elrick
  • Hype Master
« Reply #690 on: Sun, 29 June 2014, 20:44:05 »
As you should, although I am excited as well because this is a time that rarely comes around when it involves meeting GMK's moq limits and it looks like it's been done already  :thumb: .
It will take time for this key-set to get made and shipped out but it will be worth it, just like ordering a brand new Koenigsegg CCX  ;D .
Offline Cafiend
« Reply #691 on: Sun, 29 June 2014, 20:50:38 »
Yeah man that's a good point
Offline Dreamre
    • kbdlife
« Reply #692 on: Sun, 29 June 2014, 21:16:58 »
Anyone willing to part out with only their alphas? :P. You can keep all the modifiers.
Send me a PM if you're interested!
Offline osi
« Reply #693 on: Mon, 30 June 2014, 07:18:09 »
Couldn't resist -- in for a base set and spacebar set..
Offline rho0812
« Reply #694 on: Mon, 30 June 2014, 08:42:44 »
Change the message was sent, please check with us.
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
« Reply #695 on: Mon, 30 June 2014, 11:44:26 »
ordered
Offline LechnerDE
« Reply #696 on: Mon, 30 June 2014, 11:47:03 »
Wow! Almost 300 orders!
Dolch makes it possible. We probably could have reached the old MOQ of 400 as well :p
Offline Harrowed
  • My wallet has been hacked
« Reply #697 on: Mon, 30 June 2014, 15:21:06 »
Ordered right away when gb was live, been thinking extra space bars ever since. And now finally gave up... Base + color + now space! (Ergodox mods would be great too but can't get it all).
Ergodox MX Blues | Rosewill RK-9000
Offline GeorgeK
« Reply #698 on: Mon, 30 June 2014, 15:21:39 »
I already own a Dolch set but am considering placing an order for an additional Base set...  Other that "1st July", when abouts tomorrow will orders close?
Thanks
GK
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #699 on: Mon, 30 June 2014, 15:46:20 »
LAST DAY, GET YOUR ORDERS IN...
to all of you who will be saying 'damn, i missed it' tomorrow, just go buy it...
