Author Topic: GMK DOLCH [COMPLETE]  (Read 2353993 times)
Offline nobee
  • Topre! Topre! Topre!
Re: GMK DOLCH [taking orders]
« Reply #400 on: Mon, 09 June 2014, 23:06:43 »
Please all if want to make changes just resubmit the form if your previous order link isn't working. Your old order will be replaced with your new order.
Ivan,
Please forgive my extreme ignorance here but whereabouts have you posted a link to the current orders that were placed?  I would like to check what I have ordered to see if I need to get any more GMK goodness before the deadline hits me.
Just don't want to miss out on anything here.  Thanks  :thumb: .
Why don't you just resubmit a new form with everything you want? He says it'll just replace the old one.
ReΛlforce 87U (55g)   Leopold FC660C (Silenced/Lubed)   Leopold 210TP MX Red   Filco Majestouch 2 Ninja MX Brown
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #401 on: Mon, 09 June 2014, 23:42:29 »
Okay sent in another form, got some more of these sets.  I hope this baby goes over in all the sections because all these key-sets look superb  :thumb: .
Offline skuko
« Reply #402 on: Tue, 10 June 2014, 06:55:18 »
guys, can any1 link me to a comparison between GMK ABS and imsto PBT thickness?
i have these
and i would like to check the thickness compared to GMK ABS, before i jump on this dolch wagon :)
Offline gigibecali
« Reply #403 on: Tue, 10 June 2014, 07:00:17 »
67532-0
IBM M - UK  |  QFR reds  |  QFR blacks  |  HPE 87 browns  |  HPE 87 blues
Offline skuko
« Reply #404 on: Tue, 10 June 2014, 07:05:16 »
whoa, so the GMK doubleshots are even thicker? i really hope they will fit the costars good :X
Offline archer
« Reply #405 on: Tue, 10 June 2014, 07:50:38 »
I have a few GMK sets and all of them work perfectly with costar stabs, so I don't think you have anything to worry about.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #406 on: Tue, 10 June 2014, 08:38:19 »
Yes they are about same thick and of course the profile is same. GMK/Cherry doubleshot generally don't have issue with costar stabilizer as ABS is not prone to warp like PBT. I think that is reason a lot of have problem with PBT as if you look on the longer keys they are often slightly bowed on the side wall which catches. It's not even only problem with imsto's but can be on BSP or Cherry vintage PBTs too. It's not really the thickness that is issue.
« Last Edit: Tue, 10 June 2014, 08:39:55 by IvanIvanovich »
Offline findingthelimit
  • Rawr
« Reply #407 on: Tue, 10 June 2014, 09:23:24 »
i have these
where did you buy that set? :o
Poker 2 reds, GH60 42g ergo clears
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #408 on: Tue, 10 June 2014, 09:34:31 »
i have these
I think it was Ivan's first or second GB. Long time ago  :blank:
Offline skuko
« Reply #409 on: Tue, 10 June 2014, 10:57:34 »
yeah now that you mention it, i do think that enter, shifts and spacebar have the top and bottom sides a bit bent.
i have these
from classifieds, can't remember anymore :)
Offline demsix
« Reply #410 on: Tue, 10 June 2014, 16:36:20 »
Ordered.
Offline Limewirelord
« Reply #411 on: Tue, 10 June 2014, 22:48:07 »
In for a base set, color set, and two spare spacebars.
Offline bazh
« Reply #412 on: Tue, 10 June 2014, 23:26:54 »
so sad that people don't go for Fn'A :(
incase Fn'A's not gonna make it, I'll change for another color set
HHKB Pro2 white
Newbie again
Offline jinq-sea
« Reply #413 on: Thu, 12 June 2014, 06:23:40 »
I CANNOT WAIT FOR THIS. Ordered over on DT.
Offline kekstee
« Reply #414 on: Thu, 12 June 2014, 07:26:47 »
My early euphoric reaction has turned kind of stale after I noticed there is no real ISO set supported. :/
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #415 on: Thu, 12 June 2014, 07:28:40 »
Define real ISO support?
Offline LechnerDE
« Reply #416 on: Thu, 12 June 2014, 07:30:39 »
What do you mean? All the 4 ISO keys are there!
Or did you expect QWERTZ legends? That's just not doable with GMK, unless you find another 250 Germans that want to spent ~100 Euro on keycaps...
I'd be one of them though :p
« Last Edit: Thu, 12 June 2014, 07:32:57 by LechnerDE »
Offline kekstee
« Reply #417 on: Thu, 12 June 2014, 07:52:00 »
UK legends would have been nice. But yeah, I guess I will order anyway, getting all shift and enter keys is nice already.
Offline geniekid
« Reply #418 on: Thu, 12 June 2014, 08:29:55 »
Order more ODD packs please so I can get my R3 control.  Thank you.
Offline tribade
« Reply #419 on: Thu, 12 June 2014, 09:44:18 »
Amen brother. Don't need no R4 control.
KMAC mini w/ blacks | Realforce 87uw 55g w/ Digil0g case | KMAC w/ blacks | Duck Viper w/ clears
"Te occidere possunt sed te edere non possunt nefas est."
« Reply #420 on: Thu, 12 June 2014, 10:38:51 »
There is GB legends in this set for ISO, it's sideprinted on the ANSI keys. Assuming this buy makes it through which I think it will at this point... I plan to do some other language like DE (or whatever has the next biggest user share) as secondary side print for whatever colorway on the next set.
I think this approach with side printed secondary legends is the best way for other languages as it doesn't add cost to the majority of ANSI user while still bringing support to others without having MOQ issue for minority language key.
« Last Edit: Thu, 12 June 2014, 10:43:04 by IvanIvanovich »
Offline Zeal
    • Zeal Generation Inc.
« Reply #421 on: Thu, 12 June 2014, 10:47:24 »
Perhaps an updated order count would push more orders in?  :)
« Reply #422 on: Thu, 12 June 2014, 11:06:56 »
COLOR pack has reached MOQ! BASE and extra spacebar don't have too far to go.
Offline pix3l_fodder
« Reply #423 on: Thu, 12 June 2014, 12:32:59 »
Ivan if you do a language pack could you put in proper GB keys into one? As much as i appreciate the effort I'm not a fan of the side print, especially as GB users have a duplicate key.
Offline cooldiscretion
  • Convicted guilty of being totally rad.
« Reply #424 on: Thu, 12 June 2014, 12:42:09 »
I see many people have ordered additional spacebars.  Can someone explain why? The base pack comes with both sizes, why is it desirable to have > 1 of each size?
Offline ranker
    • keyboard porn
« Reply #425 on: Thu, 12 June 2014, 12:45:55 »
Placed my order of 2 sets.  Great work fellas, this is an amazing set.
Offline strict
  • TKL Zealot
« Reply #426 on: Thu, 12 June 2014, 12:46:26 »
ABS can wear down somewhat quick, especially on very commonly used keys like the spacebar, so some people buy extras to swap the worn ones out.
Offline minho
  • i'm kind of back
« Reply #427 on: Thu, 12 June 2014, 12:47:29 »
Cheap replacements as spacebar shines the fastest.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #428 on: Thu, 12 June 2014, 12:47:52 »
ABS has a tendency to shin after extended use.  The spacebar is the first key to shine, so you can replace it with an non-shiny one if you get a second set of spacebars...
Offline LechnerDE
« Reply #429 on: Thu, 12 June 2014, 12:50:26 »
Because usually the spacebar is the first key to develop shine. At least that's the reason for me :)
« Reply #430 on: Thu, 12 June 2014, 12:56:36 »
The extra 6.25 spacebar may also be wanted by people that have other Cherry sets taken from G80/G81. Since the old ones are not stem compatible with Filco, CM, Ducky et al. It might not color match with other sets, but having a useable profile matching space may be more important to some.
« Reply #431 on: Thu, 12 June 2014, 13:39:12 »
Thanks everyone, looks like I may have to get some additional spacebars as well then.
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #432 on: Thu, 12 June 2014, 23:13:43 »
Really looking forward to getting this set.
Offline Sir Bagel
« Reply #433 on: Fri, 13 June 2014, 00:58:18 »
Are the modifiers on Dolch black or a dark charcoal grey?
Offline LechnerDE
« Reply #434 on: Fri, 13 June 2014, 01:19:57 »
No, they are not black - just some dark grey.
Offline Naga
  • DansGame Hello?
« Reply #435 on: Fri, 13 June 2014, 09:34:36 »
Nice!!!
I ordered a base and a color set. RIP in pepperonis my wallet.
EDIT: I forgot about the extra spacebar set I ordered.
« Last Edit: Fri, 13 June 2014, 09:36:27 by Naga »
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #436 on: Fri, 13 June 2014, 11:22:17 »
Ordered some stuff. Wish I needed a 3rd set of Dolch but I hardly use one set at a time as is *shrug*
Offline Wildcard
  • When caffeine isn't enough
« Reply #437 on: Fri, 13 June 2014, 11:51:33 »
I just decided to order a set to compare it to my vintage sets.
Offline Grendel
« Reply #438 on: Fri, 13 June 2014, 12:17:14 »
Ordered.
- I'm game !
« Reply #439 on: Fri, 13 June 2014, 13:26:24 »
Everything should be identical barring differences in some legends and patina on old sets.
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #440 on: Fri, 13 June 2014, 13:42:32 »
I have an original, and an originative. If I sell some stuff or come into some money I may pick up a third should the group buy be in need.
Offline SSIPAK
  • ★ Bootlegcaps ★
« Reply #441 on: Sat, 14 June 2014, 02:04:21 »
will this include 6u spacebar for fc660? Thanks.
Offline LechnerDE
« Reply #442 on: Sat, 14 June 2014, 02:16:07 »
No, GMK only has molds for 6.25x and 7.00x spacebars.
Offline SSIPAK
  • ★ Bootlegcaps ★
« Reply #443 on: Sat, 14 June 2014, 02:31:59 »
whats the color of spacebar on this gmk dolch? regular black?
Offline LechnerDE
« Reply #444 on: Sat, 14 June 2014, 02:36:12 »
As shown in the mockups in the OP the spacebars will be light grey.
Offline SSIPAK
  • ★ Bootlegcaps ★
« Reply #445 on: Sat, 14 June 2014, 02:38:21 »
I apology, I meant the modifiers not spacebar.
Offline intelli78
« Reply #446 on: Sat, 14 June 2014, 03:10:04 »
Ivan, can you confirm that placing another order will overwrite your previous one? I'd like to add some things to my order, want to make sure things are updated properly.
Offline CK Briefs
  • formerly calvins1
« Reply #447 on: Sat, 14 June 2014, 03:17:25 »
He's said it here:
If you're asking about adding a new order, it should follow the same premise (at least that's the case for me whenever I deal with GB google docs)
« Last Edit: Sat, 14 June 2014, 03:20:14 by CK Briefs »
Current Keyboards: Orion - 62g ergo clears;
A87 PS2AVR - 59g ergo clears; QFR - stock blues
Offline Motan22
« Reply #448 on: Sat, 14 June 2014, 03:20:53 »
The modifiers are dark grey.
Offline intelli78
« Reply #449 on: Sat, 14 June 2014, 03:24:02 »
Thx CK Briefs.
