Author Topic: GMK DOLCH [COMPLETE]  (Read 2353890 times)
Offline Heezy
  • Formerly trynds
Re: GMK DOLCH [taking orders]
« Reply #300 on: Mon, 02 June 2014, 09:34:37 »
Sojin speaks the truth.
Updated my order to include some extra space bars. I have a feeling these will become my most used keycap sets, so I may as well spend a little extra to make them last.
how long does a well-made ABS typically last?
GMK is extremely high quality, it'll last a while.
Rig - i3 6300, 240GB SSD, 500GB SSD, Gigabyte H170N Wifi, 16GB DDR4, Zotac 1060 Mini, 650w SuperFlower
Monitor - HKC144hz Mouse/Mousepad/Keyboard - Zowie EC1A - Zowie GS-R - Zowie Camade - Filco TKL MX Pink
Offline Battou62
« Reply #301 on: Mon, 02 June 2014, 10:35:07 »
How would the quality of these compare to some original Cherry doubleshoots? I just put a set of Cherry doubleshoots on my Filco.
« Reply #302 on: Mon, 02 June 2014, 10:36:35 »
They are just like the original cherry doubleshots, GMK bought cherry's equipment etc.
Offline cooldiscretion
  • Convicted guilty of being totally rad.
« Reply #303 on: Tue, 03 June 2014, 12:27:53 »
I've been strongly considering getting the base set + color pack. Does anyone know if I would have any issues putting that on the Duck Viper second configuration with the small shift key on the right? Granted that's hoping the duck interest check turns into a group buy as well.
http://duck0113.tistory.com/81
Offline RESPRiT
  • HHKB = ❤
« Reply #304 on: Tue, 03 June 2014, 12:33:16 »
I am also planning on buying this set along with the Viper. The 1.5x shift and 1x R3 key should fit on the right end if you're planning on using that for the fn layer. Also, the GB should be coming up sometime this month.
« Reply #305 on: Tue, 03 June 2014, 12:46:34 »
Great, thanks for the quick response. I was planning to use the 1x key for fn layer. I wasn't entirely sure the shift would be 1.5x though.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #306 on: Tue, 03 June 2014, 14:13:25 »
It's a 1.75 right shift... and that is included in the base set.
Offline minho
  • i'm kind of back
« Reply #307 on: Tue, 03 June 2014, 19:06:51 »
Just to double check, shouldn't it be 1x R4 key?
Offline RESPRiT
  • HHKB = ❤
« Reply #308 on: Tue, 03 June 2014, 22:25:04 »
It was pretty late last night when'd I wrote that other reply :P These two corrections are right.
Offline GSimon
« Reply #309 on: Tue, 03 June 2014, 22:25:58 »
Leopolds are not compatible with other spacebar since they made the spacing stupid for no reason. Leopold owner should have plate modified/new plate cut with correct spacebar stabilizer size for permanent fix to problem.
So just to clarify what type of Spacebar is it? 3 or 4 stemmed?
I have the Leopold 750R so a Universal (5-6 stem) Spacebar would work, though I'm guessing the bar with this set is not Universal.
Ivan?
Offline cphead
« Reply #310 on: Tue, 03 June 2014, 22:58:51 »
Ivan?
99% sure this spacebar isn't universal, just normal.
« Last Edit: Wed, 04 June 2014, 12:48:06 by cphead »
Offline Halvar
« Reply #311 on: Wed, 04 June 2014, 02:14:29 »
We just finished a GMK space bar group buy here on GH:
GMK 6.25u space bars have four stems and fit Cherry and Filco, but not those Leopolds.
« Reply #312 on: Wed, 04 June 2014, 12:46:44 »
Leopold has what like 3 different stem spacing on their spacebar on various models, none of which are standard to anything else. As usual I simply recommend to have your Leopold plate modified to use standard stabilizer so this problem is resolved permanently.
Offline GSimon
« Reply #313 on: Wed, 04 June 2014, 13:29:41 »
If you want to get an idea the 750R's spacing looks like this: http://imgur.com/a/nUPDj
There are a few groupbuys I'm in and 2/4 of them have the universal spacebar. The Toxic GB and Round 5 - Honey Sphericals do have them but The Granite GB and the PBT B on B that you're running does not (no complaints just saying).
Anyway with the new Leopold it's less of a lost cause that's why I asked, I wouldn't think to mod this board for that as I have 4 different colors and 6 different spacebars to choose from anyhow.
« Reply #314 on: Wed, 04 June 2014, 13:48:16 »
I don't believe SP 'universal' spacebar works on Leopold either unless something changed recently. Last time I know it only have the 2 outside pairs and the 2 different positions for the switch in center. GMK 6.25 spacebar is same.
Offline GSimon
« Reply #315 on: Wed, 04 June 2014, 13:56:34 »
If the SPs universal has spacing identical to the Poker ii's spacebar it would be.
Newer production sets should have universal spacebar which fits Leopold.
^^^In a thread asking about the 200R, which has the same spacing as the 750R
« Last Edit: Wed, 04 June 2014, 13:59:35 by GSimon »
« Reply #316 on: Wed, 04 June 2014, 14:03:30 »
I have no idea to what context that is... so either I was talking about some other sets like those available for Keycool and etc, or I was wrong about something.
Offline Halvar
« Reply #317 on: Wed, 04 June 2014, 14:24:18 »
GMK space bars (from the recent buy) have but one pair of outer stems, and the distance center to center between them is 100 mm, like on a Filco or a Cherry MX-3000.
SP space bars and EK space bars have an additional  second pair, with a distance center to center of 80 mm from each other, like on an FC200.
There were Leopold space bars with a distance of 85 mm, so for these keyboards neither will fit.
« Last Edit: Thu, 05 June 2014, 01:36:23 by Halvar »
Offline GSimon
« Reply #318 on: Wed, 04 June 2014, 14:26:03 »
http://geekhack.org/index.php?topic=29257.0
Thanks, what I was looking for.
« Last Edit: Wed, 04 June 2014, 14:29:41 by GSimon »
Offline fl0w3n
« Reply #319 on: Wed, 04 June 2014, 16:10:52 »
Hell chea... IN
Offline ideus
  • Björkö.
« Reply #320 on: Wed, 04 June 2014, 16:19:21 »
order that color pack just for the winkeys :)
I am considering the same here. I still have time to make my mind.
Offline Photoelectric
« Reply #321 on: Wed, 04 June 2014, 16:35:06 »
I'd split one to get the teal non-ISO Enters and arrow cluster :)
Offline swornxin
    • Nailed Down Custom Pins
« Reply #322 on: Wed, 04 June 2014, 23:47:17 »
Lots of discussion about the 750R but what about the FC660M. Really what I was getting the set for. Not that I'll be backing out, but still wondering.
Thanks
Octagon - 62g Cherry tactile greys
Phantom - 65g Cherry tactile greys
FC660M - Cherry blues
KC60 - Gateron browns
Offline GSimon
« Reply #323 on: Thu, 05 June 2014, 00:15:50 »
Thanks
Nah, looks like it's going to be 3 stem. Even if it was universal it wouldn't work...
Offline swornxin
« Reply #324 on: Thu, 05 June 2014, 01:53:24 »
Thanks
Thanks for the quick response. Unfortunate, but I will live. Might have to have two Pokers with Dolch on them. Different profiles, so things could be worse.
Offline Halvar
« Reply #325 on: Thu, 05 June 2014, 03:23:25 »
Maybe GMK can in fact make universal space bars with six stems? Their current design looks like extra stems were planned at some point, but omitted ...
67023-0
Offline IPT
  • Formerly projectD
« Reply #326 on: Thu, 05 June 2014, 09:28:14 »
spacebar is the #1 reason i sold my 700R =(
Offline LechnerDE
« Reply #327 on: Thu, 05 June 2014, 09:31:21 »
Orders have slowed down quite a bit :(
Hopefully this GB will gain some momentum again when the deadline approaches.
I will definitely order a second set if it makes a difference!
« Reply #328 on: Thu, 05 June 2014, 09:32:04 »
I have a GMK spacebar on my 700R right now. I just put blue tack/poster putty on the stabilizers and then sat the center stem on the switch. Works fine with only a slight difference inf eel.
« Reply #329 on: Thu, 05 June 2014, 09:51:10 »
I can ask about that again on the 6.25 spacebar... it might be possible.
Offline GSimon
« Reply #330 on: Thu, 05 June 2014, 12:46:17 »
Ya! Would be nice, I'm on the fence with getting the full set due to already committing to other GBs but if there spacebar's good to go it could sway my decision.
Offline ideus
  • Björkö.
« Reply #331 on: Fri, 06 June 2014, 08:38:35 »
My budget is already over limit, but I think this is a GB I just can't pass by. The original Cherry DS key caps I have are the ones I feel better so far. even if they are shiny the grip is even better. I have some weeks to make my mind.
« Reply #332 on: Fri, 06 June 2014, 08:50:00 »
We still need all the help we can get. Even if one can't afford the full set perhaps a color pack. It's still helping an option to reach the moq.
Offline cjhard
  • Claudia the Magnificent
« Reply #333 on: Fri, 06 June 2014, 09:15:59 »
Yes, please add some color, F'n'A, and even oddmods to all your orders so the minority of us can rest easy that they will be produced :)
Offline ideus
  • Björkö.
« Reply #334 on: Fri, 06 June 2014, 09:23:39 »
Ivan: What happen if someone is in for the base and the odd set, but the odd set does not reach MOQ?
Offline RESPRiT
  • HHKB = ❤
« Reply #335 on: Fri, 06 June 2014, 09:39:30 »
Ivan might just inform everyone that needs the odd set that it won't go into production and maybe will leave it up to the discretion of odd users whether or not they still want to participate.
Offline avtar
« Reply #336 on: Fri, 06 June 2014, 09:41:24 »
Regarding reaching the MOQ, has anyone posted info about this group buy on other sites?
Offline RESPRiT
  • HHKB = ❤
« Reply #337 on: Fri, 06 June 2014, 09:42:59 »
DT is aware of it if I'm not mistaken.
« Reply #338 on: Fri, 06 June 2014, 09:44:56 »
Someone's posted a link on OTD.
« Reply #339 on: Fri, 06 June 2014, 09:45:30 »
I tattooed the URL on my forehead so the general public knows.
Offline RESPRiT
  • HHKB = ❤
« Reply #340 on: Fri, 06 June 2014, 09:47:10 »
I hope you used a shortened URL :D
« Reply #341 on: Fri, 06 June 2014, 10:03:43 »
Basically, when the deadline comes around I will look to see how close options are to MOQ. At that time I may decide 1 time extension may help if it is very close to making the amount, or possibly just take advantage of the moq shortfall pledges if there is enough assistance from that.
As far as other forums go, I am unaware of any others where info about this buy may be posted that I didn't post myself either here, on DT or bit-tech. Please do feel free to help spread the word around to any others that may be interested. It is open to anyone all around the world.
Offline avtar
« Reply #342 on: Fri, 06 June 2014, 10:05:42 »
I just posted it on /r/mechmarket. I really hope this one makes it.
« Reply #343 on: Fri, 06 June 2014, 10:45:36 »
Congrats to Ivan for becoming a moderator!! :D
Offline IPT
  • Formerly projectD
« Reply #344 on: Fri, 06 June 2014, 12:17:21 »
as stupid as this sounds, the lack of a grey winkey is making me hesitate in joining.
yeah i have no interest in the color pack winkey.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #345 on: Fri, 06 June 2014, 12:22:26 »
I am getting the base kit already.  The only keys I wish I could get would be the dark color for the [ | \ ] key and the [ ~ ` ] key.
I am guessing these are not available due to the historic mold setup...
Offline lightsout714
« Reply #346 on: Fri, 06 June 2014, 12:22:45 »
Yeah I hate having a blank mod. Looks "cheap" or incomplete to me. But he can't make everyone happy so I understand.
Offline elton5354
« Reply #347 on: Fri, 06 June 2014, 12:25:48 »
I wish there are windowed Num Lock, Caps Lock, and Scroll Lock.  Blanks...
And Colour Pack arrow keys for the bottom rows would be cool.
Offline LechnerDE
« Reply #348 on: Fri, 06 June 2014, 12:43:04 »
I'd prefer the symmetric look as well, but this is a neverending debate. Technically those keys are alphas and therefore should have the alpha color...
As far as I know this has nothing to do with mold setups. It's just a little more expensive to offer 2 extra keys and Ivan want's to keep the price as low as possible.
« Reply #349 on: Fri, 06 June 2014, 12:53:01 »
Yes, well basically I just made the colorscheme same as the original... there is nothing more to that decision. It's impossible to please every buyer... but I tried to come up with the best compromises I think in most cases on key selection. It's not going to change for this buy. I think changing things midway can create other problems and confusion which I don't want. Next time there is an IC is when you should bring up these topics.
