Author Topic: GMK DOLCH [COMPLETE]  (Read 2353889 times)
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: GMK DOLCH [taking orders]
« Reply #250 on: Tue, 27 May 2014, 09:07:56 »
MX8000 series is pretty much a direct fit for Filco and etc. if you don't mind relegendable... the spacebar is still incompatible though.
If you are unsure your order/want to change it and didn't save the order link or it doesn't work... please just resubmit the form. Only the most recent entry is kept. It saves us both time to do it this way rather than ask me to check it/edit for you.
Also if you have any question that dosen't require an answer with personal info... please ask in the thread rather than PM me. Chances are other people may have same or similar question that I can answer 1 time.
« Last Edit: Tue, 27 May 2014, 09:10:02 by IvanIvanovich »
Offline exitfire401
  • The Force is Re/\l
« Reply #251 on: Tue, 27 May 2014, 09:08:59 »
Awesome, will do that now. Thanks, sir!
Offline LechnerDE
« Reply #252 on: Tue, 27 May 2014, 15:30:34 »
Why all the SP hate in this thread lol. What did they do to wrong us?
Ultra tight fitting Retro Key-set, broke a couple stems off the keys removing them from my Filco's, WASD's and a couple of Leopold's (hated that).  Same with Miami, Valentine V1, 23 Commando (1 stem broke), CC&G R2 (2 stems), Red Alert V1, Sanctuary and Hazard Keyset.
You might be wondering why I keep buying SP key-sets because I have lots more that haven't broke sitting in quite a few working keyboards.  Just be aware that a certain percentage of poorly built keys still get shipped out without SP even bothering to use any decent quality checking procedures.
Of course now when buying any further SP made key-sets I still need to buy a tub of KY to fit the keys onto each keyboard now.  Amazing how a little lubricant can save you from any hardship  :thumb: .
Maybe you should work on your pulling technique - I have all the sets and boards you mentioned (except WASD) and never broke a single stem.
Dafuq are you doing? Ripping off the caps with your teeth :p
In serious news:
I have finally placed my order - let's do this!
Offline Pacifist
  • on hiatus
« Reply #253 on: Tue, 27 May 2014, 15:34:56 »
old sp tooling for dsa was designed to be tight af because it was made for industrial use where they drop keyboards a lot and don't want to put them back on :-\
Offline esoomenona
  • Gnillort?
« Reply #254 on: Tue, 27 May 2014, 15:38:39 »
So we're doing more Dolch? I guess this is my life now...
« Reply #255 on: Tue, 27 May 2014, 15:39:59 »
Yeah wheres my Miami or Hawaii? Or something fun like purple on teal??
Offline Pacifist
  • on hiatus
« Reply #256 on: Tue, 27 May 2014, 15:40:55 »
Hawaii? What color scheme is that?
Offline Motan22
« Reply #257 on: Tue, 27 May 2014, 16:14:35 »
GMK Miami with white legends would be complete and utter bliss. The GMK Magenta and Cyan are so vibrant!  :thumb:
Offline lightsout714
« Reply #258 on: Tue, 27 May 2014, 16:19:34 »
We should save those colors for the ladies :P
Offline domoaligato
« Reply #259 on: Tue, 27 May 2014, 19:04:44 »
SP fixed the tooling for DSA. If you read the thread that binge started, I contacted SP and reported the issue to them and SP followed-up with me that they had found and fixed the issue.
DSA Retro is the only GB that had this issue.
Offline IPT
  • Formerly projectD
« Reply #260 on: Tue, 27 May 2014, 19:10:31 »
im guessing ivan wants at least 1 GMK fullset GB he's trying to run to hit MOQ
« Reply #261 on: Tue, 27 May 2014, 19:15:36 »
If was pink is good enough for Killa Cam, it's good enough for me. I think the wise man once said, "*****es say I'm tacky daddy, Range look like Laffy Taffy".
We're certainly not hitting MOQ with that attitude :P
Offline Michael
  • Formerly Bro Caps
« Reply #262 on: Tue, 27 May 2014, 19:17:13 »
Next GB, Ivan. Do it. Do it.
« Last Edit: Tue, 27 May 2014, 19:19:54 by Bro Caps »
« Reply #263 on: Tue, 27 May 2014, 19:20:29 »
Yes please, purple on pink with a Hello Kitty dyesubbed escape.
« Reply #264 on: Tue, 27 May 2014, 19:51:27 »
I would like to do some different things, with other colorways... but I always worry they won't make MOQ on full sets. Even small color packs may be very tough for some combinations.
« Reply #265 on: Tue, 27 May 2014, 20:14:16 »
Need something like an Esc or function row kit as a spoiler for a new design.
Although the GMK mini packs didn't go that well :rolleyes:
Offline domoaligato
« Reply #266 on: Tue, 27 May 2014, 20:16:17 »
we should start another IC thread so that we stop cluttering this one up. :D
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #267 on: Tue, 27 May 2014, 21:34:59 »
I use a traditional stainless steel key-cap puller, heavier tool than the standard Filco key-cap puller supplied in your Filco keyboard package.  The caps once inserted are then difficult to remove no matter how gentle you become.  I admit I'm no delicate angel when it comes to handling small, tiny objects like key-caps but when I pull the cap it literally separates from the stem and sure enough I have the broken stem left on the Cherry switch.  Which drives me insane beyond words  >:D .
Of course I heavily apply lubricant and the keys can now be removed easily without any breakage.  Although now I simply fill a keyboard with SP key-caps then leave it there permanently because I can't risk removing them.  I don't apply them onto any Korean Keyboard for fear of any damage because you do change key-sets on them when it comes to GMK beauties.
« Last Edit: Tue, 27 May 2014, 21:36:42 by Elrick »
Offline tbc
« Reply #268 on: Tue, 27 May 2014, 21:50:41 »
i broke the top of my clear cover once trying to a get a dsa cap off of a pcb mounted clear switch.  quite sad :(
Offline domoaligato
« Reply #269 on: Tue, 27 May 2014, 22:21:18 »
Elrick and tbc, Do you even read what I post?
Offline domoaligato
« Reply #270 on: Tue, 27 May 2014, 22:35:47 »
Retyping this again. :(
1. The clear switch covers that obo studio made that we all bought are ****.
It doesn't matter what keycaps you put on them. Your going to break the brittle POS switch tops they sold us.
2. SP fixed the dsa tooling and every set made after dsa retro is fine and does not damage the switches.
3. Again this **** has no place in a group buy thread.
Sorry Ivan.
Offline TLSC.wipeOut
  • "Who dares, wins"
« Reply #271 on: Wed, 28 May 2014, 15:29:10 »
how much for each extra spacebar??
OTD 456GT with Lubricated 68g Gold Spring MX Clears and GMK Dolch Keycap set
WTB: KMAC2 kit
Offline Zeal
    • Zeal Generation Inc.
« Reply #272 on: Wed, 28 May 2014, 15:29:53 »
~$6 USD for a pack of 6.25u and 7u spacebar.
Offline clickclack123
« Reply #273 on: Wed, 28 May 2014, 21:07:16 »
How high would the profile be of the ergodox mods? I'm hoping they're similar to the low-profile ones on the Cherry MX Board 2.0 (middle one here).
66301-0
edit: Haha just realized that there'd need to be another 243 ergodox orders over the next two days for this to happen.  :))
« Last Edit: Wed, 28 May 2014, 21:10:10 by clickclack123 »
« Reply #274 on: Wed, 28 May 2014, 21:10:57 »
Those low profile caps from the G80-3800 are devlin caps I believe not GMK or cherry. And orders close July 1st not June 1st.
Offline minho
  • i'm kind of back
« Reply #275 on: Wed, 28 May 2014, 22:39:39 »
Next two days...? Isn't the GB deadline July 1, not June 1?
edit: I'm bad at reading posts right above mine apparently.
« Last Edit: Wed, 28 May 2014, 23:18:29 by minho »
« Reply #276 on: Wed, 28 May 2014, 23:15:22 »
Oops. Still seems pretty unlikely that ergodox sets will make the MOQ.
Offline minho
  • i'm kind of back
« Reply #277 on: Wed, 28 May 2014, 23:46:37 »
Just out of curiosity, what is the purpose of buying extra space bars if a 6.25 and 7 already come with the base set?
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #278 on: Wed, 28 May 2014, 23:48:41 »
Extras, they're the first key to shine up usually.
Offline domoaligato
« Reply #279 on: Thu, 29 May 2014, 02:32:51 »
Spacebars and wasd and the first to shine for me.
Offline padath
« Reply #280 on: Thu, 29 May 2014, 02:36:43 »
Left shift (ISO) is the first to shine for me :-S
« Reply #281 on: Thu, 29 May 2014, 12:03:36 »
The DOX mods are just like a normal Cherry set with sculpted profile E-B rows, so they would match profile for standard Cherry alpha keys in their respective rows. You can always help spread the word that DOX is available. I'm pretty sure there are more than 250 total users of this board out in the world that may want something nicer than the SP offerings that have previously been available. Even if they are not interested in any other options offered here... combing them with a used $10 7000 set would be a good value.
« Last Edit: Thu, 29 May 2014, 12:05:34 by IvanIvanovich »
Offline GSimon
« Reply #282 on: Thu, 29 May 2014, 13:04:30 »
I'm a sucker for the colored keys so I ordered the color pack (more GMK esc keys :D).
I like the base set, looks top notch quality, but the colors are too blah for me, as in too modest/subtle.
« Reply #283 on: Thu, 29 May 2014, 13:13:43 »
I said no to this set too many times. I couldn't say no again. I'm in. Dolch was one of the color schemes that drew me into keyboards. It'll look nice on a board with really bright LEDs like my Pure with magenta LEDs or my upcoming custom 1800 which will have cyan/magenta/white LEDs.
Offline domoaligato
« Reply #284 on: Thu, 29 May 2014, 13:43:45 »
« Reply #285 on: Sun, 01 June 2014, 11:30:09 »
Almost half way to MOQ on BASE :)
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #286 on: Sun, 01 June 2014, 11:38:30 »
Yeah very quickly while we have around a month :) I feel base, color, spacebar 'll hit MOQ soon :3
Offline findingthelimit
  • Rawr
« Reply #287 on: Sun, 01 June 2014, 14:09:45 »
Does the color of the dolch spacebar differ from the color of the classic beige spacebar by a large margin?
Poker 2 reds, GH60 42g ergo clears
Offline intelli78
« Reply #288 on: Sun, 01 June 2014, 14:49:22 »
Yes,  it's a totally different color
Offline isaske
  • Stop whining!
« Reply #289 on: Sun, 01 June 2014, 15:46:04 »
I have another question
Do the buttons left to 1 and under Backspace come in dark gray/alpha color too? I like it better if they are the same color as the alphas.
HOW DO I COMPUTER?
« Reply #290 on: Sun, 01 June 2014, 16:14:38 »
Keys come as show in the first post.
Offline RaVNzCRoFT
  • * Commercial Vendor
« Reply #291 on: Sun, 01 June 2014, 19:51:23 »
Same shading as in the OP but with these colors, right?
<<< Click to view
« Reply #292 on: Sun, 01 June 2014, 22:58:12 »
Yeah same thing, with some minor legend difference.
Offline Oobly
« Reply #293 on: Mon, 02 June 2014, 03:17:22 »
Updated my order to include some extra space bars. I have a feeling these will become my most used keycap sets, so I may as well spend a little extra to make them last.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline GSimon
« Reply #294 on: Mon, 02 June 2014, 03:39:24 »
Leopolds are not compatible with other spacebar since they made the spacing stupid for no reason. Leopold owner should have plate modified/new plate cut with correct spacebar stabilizer size for permanent fix to problem.
So just to clarify what type of Spacebar is it? 3 or 4 stemmed?
I have the Leopold 750R so a Universal (6 stem) Spacebar would work, though I'm guessing the bar with this set is not Universal.
Offline naasfu
  • The Curator
  • CURSE YOU HE-MAN
« Reply #295 on: Mon, 02 June 2014, 04:14:16 »
Finally got around to placing my order.  I already have GMK Dolch, but I love it so much that I'm getting another set.  1x base, 1x color pack, 3x spacebars.
Thanks, Ivan!
Offline whentheclouds
« Reply #296 on: Mon, 02 June 2014, 05:23:20 »
how long does a well-made ABS typically last?
Offline RESPRiT
  • HHKB = ❤
« Reply #297 on: Mon, 02 June 2014, 07:15:32 »
GMK is extremely high quality, it'll last a while.
Offline bazh
« Reply #298 on: Mon, 02 June 2014, 07:18:51 »
Ordered!
Damn, moarr love for Fn'A, people :(
HHKB Pro2 white
Newbie again
Offline cjhard
  • Claudia the Magnificent
« Reply #299 on: Mon, 02 June 2014, 09:12:52 »
Bought my car, moved to a new apartment, and still enough time and cash left over to secure a spot in this GB.
I hope Oddmods reach MOQ. I understand now that I still won't have a nice spacebar for my Minila, so I bought a Poker II to replace it :P
