Author Topic: Help with circuit?  (Read 1922 times)
Offline adventurepoop
  • I make keyboards, I guess.
Help with circuit?
« on: Thu, 22 May 2014, 14:08:35 »
After finding out I wired up my 5 key keyboard wrong last time, and finding out I only had 3 usable io, I came up with this as a circuit.
http://imgur.com/71QqrdD
With switches 1-5 and io abc, Would this work? I don't know much about circuits but it looks like it to me :o
Offline Smasher816
  • HHKB Master
Re: Help with circuit?
« Reply #1 on: Thu, 22 May 2014, 14:49:38 »
Mind rotating the image, it would help everyone see it better. Imgur has that feature built into its edit menu.
« Reply #2 on: Thu, 22 May 2014, 15:22:42 »
Actually I figured it out, but yeah I didn't know at the time
Offline Smasher816
  • HHKB Master
« Reply #3 on: Thu, 22 May 2014, 17:07:51 »
Glad you got it figured out.
Offline OldDataHands
« Reply #4 on: Thu, 22 May 2014, 17:26:36 »
Nope. This circuit will not do what you want. For example: switches 1 and 5 are indistinguishable. As long as you are ok with ghosting above 1 key pressed you can use more diodes... if you have analog inputs, you have some good options...
