Author Topic: Quickfire TK's Windows/FN/Numpad0/Alt Keys  (Read 2747 times)
Offline Kayla
  • :3
« on: Thu, 22 May 2014, 19:05:32 »
So I'm trying to outfit a blue switch TK but while keycap shopping I noticed that the alt keys are 1.25 control keys are 1.5 the windows and function and numpad 0 keys are 1.0 (I can replace numpad with arrows).. if I'm going to purchase, for example the bi-color set from vortex, how would I go about plugging those odd key sizes in without disrupting the gorgeous look of the keyset?
Edit: The space bar seems to be a different size too...?
« Last Edit: Thu, 22 May 2014, 19:10:46 by Kayla »
Offline tbc
Re: Quickfire TK's Windows/FN/Numpad0/Alt Keys
« Reply #1 on: Thu, 22 May 2014, 19:25:26 »
you have a 'gamer' layout (not a real term) and you've unfortunately discovered why gamer boards are  bad :(
you CANNOT buy a set from vortex that will cover your board properly.  vortex DS PBT is moogle only.
more generally, you'll need BOTH a moogle (1.25x) and a tsangan (1.5x) set AND get a 1x winkey from somewhere (some tsangans include them, some don't) (you can also just use a blank key from the cursor block or numpad if you're agreeable with that).
most likely, you'll  never find a most produced set that has tsangan and moogle; you'll need to buy a GB keyset.  checkout sites like: techkeys.us, keypop.net
you're going to have a real hard time finding something for your spacebar.  your best bet is to check out ivan's GMK dolch GB when it becomes available (but this is abs and will be 2-3 months at the earliest) or find something in SP's inventory systen.
« Last Edit: Thu, 22 May 2014, 19:29:06 by tbc »
Offline Kayla
  • :3
« Reply #2 on: Thu, 22 May 2014, 19:40:35 »
Thanks so much for the quick reply. I'l look into it; and in the mean time look into finding a tenkeyless board within my price range with regular key sizes. ; ;
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #3 on: Thu, 22 May 2014, 19:53:45 »
You could always grab a DOLCH set from my groupbuy. It has everything to fit a TK properly though the spacebar will have small gap on each end.
Offline Pacifist
  • on hiatus
« Reply #4 on: Thu, 22 May 2014, 19:55:53 »
GB started :eek:
Offline Kayla
  • :3
« Reply #5 on: Thu, 22 May 2014, 20:15:31 »
I really would love to but I want something colorful because my current keyboard is dreary.. x3 I think the set is gorgeous though.
