Author Topic: HHKB Lite (KB-9975 / PD-KB100NB) - Steam Punk Key HELP  (Read 2078 times)
Offline CaptCarrot
« on: Sun, 25 May 2014, 17:23:02 »
I recently acquired a PS/2 HHKB Lite.  The plan is to build it into something and steam-punk it.
But I have hit a stumbling-block - I'm being lazy so I am borrowing the photo from this thread -Topic: What Keycaps? ;)
Obviously, I don't want to destroy the HHKB keys, in case I want to re-use them.  Short of buying a complete replacement set, is there any other way that you can think of that will allow me to add steam-punk style (think typewriter) keys?
Also, if searching for replacement keys, is there any specific name for this type?
Thanks.
Re: HHKB Lite (KB-9975 / PD-KB100NB) - Steam Punk Key HELP
« Reply #1 on: Mon, 26 May 2014, 00:02:21 »
HHKB Lite keyboards are not expensive - the best option might be to buy another one or two.
Or I have seen other rubber dome keyboards that are even cheaper, but which have similar keycap stems.
Offline CaptCarrot
« Reply #2 on: Mon, 26 May 2014, 08:34:25 »
Thanks.
I just pulled a cap off a keyboard at work and it seems the same - time to hit the charity shops methinks.
