Author Topic: Red Alert left shift filco compatability issue.  (Read 3781 times)
Offline Reckthor
    • PC Stuff
« on: Sun, 25 May 2014, 22:34:47 »
I'm having an issue with my left shift rubbing on the case on my Filco not allowing it to move freely.
Anyone know a fix for this?
thank you for any help!
Offline Pacifist
  • on hiatus
Re: Red Alert left shift filco compatability issue.
« Reply #1 on: Sun, 25 May 2014, 22:36:35 »
that shouldn't happen
did you put the stab inserts on the right way?
Offline Reckthor
    • PC Stuff
« Reply #2 on: Sun, 25 May 2014, 22:37:50 »
Yes Sir
Offline phoenix1234
« Reply #3 on: Sun, 25 May 2014, 22:39:30 »
Please make sure the Costa inserts were installed properly.
I like linear switches
Offline Pacifist
  • on hiatus
« Reply #4 on: Sun, 25 May 2014, 22:39:43 »
post some pictures, this is quite strange
Offline Reckthor
    • PC Stuff
« Reply #5 on: Sun, 25 May 2014, 23:13:22 »
« Reply #6 on: Mon, 26 May 2014, 00:03:54 »
Do the other keys along the left side of the keyboard also rub?
« Reply #7 on: Mon, 26 May 2014, 01:15:09 »
How soon we all forget. :)
This is a known issue with Filco keyboards and SP keycaps. Sometimes the manufacturing tolerances for both overlap and you end up with a keycap that rubs against the side of the keyboard housing. To fix it, you can try shaving a tiny bit of plastic off the offending keycap, a bit at a time, until it clears the keyboard housing enough to function properly. It's been suggested to do this by sanding with fine grit sandpaper, going slowly, a little bit at a time.
« Reply #8 on: Mon, 26 May 2014, 02:09:06 »
Is this the case for all keycaps along the left side of the keyboard?
The OP's pics only show the left Shift in place.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #9 on: Tue, 27 May 2014, 16:20:49 »
What jdcarpe said is correct, it has happened to me before on imsto thick PBT's enter key, also one of the shift on the new Vortex bi-color PBT.
Doesn't always happen, but once in a while if you get unlucky then it does.
Sometimes it rubs against the stabilizer wire, sometimes it rubs against the bottom plastic mount for stabilizers (the one that mount on the steel plate).
In this case you might have to shave off the inside of keycap a little bit, unless you can find a safe way to bend the keycap outwards.
Good luck my friend !
« Reply #10 on: Tue, 27 May 2014, 18:15:35 »
Sounds more like a Filco problem than a keycap problem, especially if it spans different keycap sets.
Offline lolkey
« Reply #11 on: Tue, 27 May 2014, 20:28:10 »
try setting the keycap on a table and seeing if it sits flat or is slightly warped. if it's warped, take a blow dryer to it.
filco ninja mj2 tkl · mx brown · black case · blank black pbt
varmilo va87mr tkl · gateron red · black case · dye sub pbt ❤
vortex pok3r rgb · mx silent · white case · blank xda pbt
« Reply #12 on: Tue, 27 May 2014, 20:39:21 »
Looks pretty flat from the pictures.
This would work for a space bar, not so sure about the shorter keys.
« Reply #13 on: Wed, 28 May 2014, 18:18:26 »
I have the same problem on my Camo. Custom keycaps seem to have this issue with Filcos. I don't have this problem with GMK keycaps, however.
Offline ebacho
« Reply #14 on: Wed, 28 May 2014, 18:30:31 »
This is my experience too; SP left shift tends to grind against the left wall, while imsto/OG Cherry/GMK is fine.
