Author Topic: Cheapest place to get Cherry Blues  (Read 2223 times)
Offline Manyak
« on: Fri, 01 May 2009, 17:43:47 »
I need 104 of them, and the only place I know of to get them from is Digikey. And $0.64 per switch comes out to $66, which is even more expensive than harvesting them from a Scorpius M10.
Anyone know?
Oh, and maybe around 5 Cherry Greens if anyone actually carries them.
Currently Owned:
Filco FKBN104MC/EB - Model M 1390131 \'86 - Model M 1391401 NIB - Unicomp Endurapro NIB - iRocks KR-6230 - Compaq MX-11800 - Cherry G80-8113HRBUS-2 - Cherry ML-4100 - Cherry MY-8000-something - Dell AT101W (Black) - ABS M1 - Siig Minitouch - Chicony KB-5181 w/ SMK Montereys - Chicony KB-5181 w/ SMK Montereys NIB - Cherry G80-3494LYCUS-2 - Deck Legend
Offline huha
« Reply #1 on: Fri, 01 May 2009, 18:06:05 »
The cheapest way seems to be harvesting them from actual keyboards. It's incredibly stupid, but they're just expensive in small quantities.
Greens seem to be blues with a different spring. I opened one up and it could be the spring used in blacks; I'll elaborate on this as soon as my Cherry G80-3000 with black MX arrives (which was somewhat cheap), but judging from pictures comparing the two, it does look suspiciously like the spring used in blacks.
-huha
Unicomp Endurapro 105 (blank keycaps, BS) // Cherry G80-3000LSCDE-2 (blues, modded to green MX) // Cherry G80-3000LAMDE-0 (blacks, 2x) // Cherry G80-11900LTMDE-0 (blacks, 2x) // Compaq G80-11801 (browns) // Epson Q203A (Fujitsu Peerless) // IBM Model M2 (BS) // Boscom AS400 Terminal Emulator (OEM\'d Unicomp, BS, 2x) // Dell AT102DW (black Alps) // Mechanical Touch (chinese BS) Acer 6312-KW (Acer mechanics on membrane) // Cherry G84-4100 (ML) // Cherry G80-1000HAD (NKRO, blacks)
Offline ozar
« Reply #2 on: Fri, 01 May 2009, 18:09:51 »
I was thinking that there were a few people here that were talking about going in together on a large quantity of blue cherry switches in order to save some money, but I can't find that thread now, if it ever existed.  Could have just been a dream... don't know.
Offline Manyak
« Reply #3 on: Fri, 01 May 2009, 18:25:21 »
Well if its just the spring used in blacks that makes it easy, since the board I'm going to be switching out uses blacks to begin with (the deck).
So I guess the next question then would be - which cherry blue keyboards use MX1A-EINW and which ones use MX1A-EINN? I'm not 100% sure if they use the ones with the two 'stabilizing posts' or not.
Currently Owned:
Offline huha
« Reply #4 on: Fri, 01 May 2009, 18:37:26 »
The G80-3000 uses MX1A-E1JW switches.
-huha
