Author Topic: FC660C vs HHKB Type-S  (Read 4426 times)
Offline OnTheBrink
  • Work Hard. Play Harder.
    • Wired In Store
« on: Mon, 26 May 2014, 21:38:31 »
Okay, I searched around and got mixed responses on this so I want to collect some feedback.
I wanted a Type-S as my first Topre. This is because I fell in love with the silenced sound of a Topre. I purchased an FC660C with the objective of modding the board to save money. While before I fell in love with the sound, I now fell in love with the feel, so I bought some landing pads, ironed them down, opened up a tutorial, carefully popped this puppy open and after hours of taking my time to not get a single scratch, chip or crack on or in the board; I modded my first keyboard.
I didn't like the reduction in travel distance at all. I understand(stood) what people mean(t) by it not reducing the travel distance by much, but I guess I have sensitive fingers. I actually closed up the entire keyboard and tried using it and it just took away the whole Topre experience for me so I demodded it (yes, I know demodding isn't a word). The switches actually felt borderline linear in my opinion. This brought me all the way back to staring down a Type-S again. From my understanding, the stems were made a little longer so when it was modded, it does not reduce the travel distance. I am just about ready to throw this on the classfields, but like I said, I received some mixed input.
Some people say the FC660C feels more solid and others say it is the layout. Can someone who can remain objective and/or not give in to new purchase euphoria (meaning they like one or the other more because that is their most recent board) give me a solid comparison?
Since my main concern is the keyboard feeling solid but I do want the silencing, is the FC660C so much more solid that it outweighs the Type-S, or does the 'thock' of a Type-S and/or the layout of an HHKB still make it king of the Topre?
Thanks guys.
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
Re: FC660C vs HHKB Type-S
« Reply #1 on: Mon, 26 May 2014, 21:42:50 »
My advice: if you have the money, don't solicit opinions; just try it for yourself. Worst case is you sell it "like new" and lose out on a small bit of cash. Best case you find your end game board and don't have to keep spending money on keyboarding. ;)
Offline exitfire401
  • The Force is Re/\l
« Reply #2 on: Mon, 26 May 2014, 21:44:09 »
Thanks guys.
I attempted to do the same mod as you before I did the o2dazone mod, and also hated the feeling. o2dazone (silicone sheet and metal punches) was great because it does not modify the travel of the switch at all. I can't speak for anything about the type-s unfortunately, but I am planning on buying one in the future. As for the fc660c, it's a wonderful board, and if you try the o2dazone mod, I feel like you'll be more than happy with the outcome.
Offline jwaz
  • * based mod
  • #geekhack on freenode
« Reply #3 on: Mon, 26 May 2014, 21:47:08 »
It isn't really worth it for the money unless you can pick one up on sale or in the classifieds but I'd go Type-S all the way. I'm huge fan of the amount of travel vs o-rings (which I hated, way too much travel loss).
I use both the Pro 2 and Type-S, to be fair I haven't tried a 660c for an extended period of time but I do have topre boards with a plate and I can't really stand that layout.
Offline OnTheBrink
    • Wired In Store
« Reply #4 on: Mon, 26 May 2014, 21:59:19 »
Would you say that the plated Topres you use feel much more solid than a Type-S or not really? To add to that, do you feel the silencing in the Type-S adds to the solidity of the board's feel?
Offline OnTheBrink
    • Wired In Store
« Reply #5 on: Mon, 26 May 2014, 22:00:58 »
Thanks guys.
I might do that actually but if it did not reduce the travel distance, what made you dislike the feel?
Offline allocerveau
« Reply #6 on: Tue, 27 May 2014, 02:02:38 »
Went from a HHKB Pro 2 to a HHKB Pro 2 Type-S, their is no travel reduction at all (the switch on the Type S is in fact a little bit longer to compensate for the landing pad). The feeling is exactly the same as on the HHKB, minus the "plastic-y" noise when you lift up the key. Instead you get a nice double 'thock' each time you press and release the key. If you like the HHKB, you'll like everything about the Type-S.
Offline AKIMbO
  • HHKBro
« Reply #7 on: Tue, 27 May 2014, 06:52:55 »
I believe it's only the silenced realforce boards with purple plungers that have a different stem design to compensate for the loss in depth the switches have a result of the silencing disks. The hhkb type s is identical to  an unsilenced hhkb except for having a silencing disk around each stem (ie. the type s and unsilenced hhkb use the exact same stem).
| KBD75 (box reds)
Offline Xowie
  • On Sabbatical
« Reply #8 on: Tue, 27 May 2014, 07:28:02 »
I agree with this advice. From looking at the classifieds, HHKBs typically have no problem selling. Paying a 10ish% premium to try out a new board is worth it to me.
RETIRED
