Author Topic: Quick circuit help  (Read 2131 times)
Offline adventurepoop
  • I make keyboards, I guess.
Quick circuit help
« on: Tue, 27 May 2014, 17:40:55 »
For my 5 key, Are the diodes needed in this circuit? I'm thinking they aren't, but I know you need them for a matrix.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
Re: Quick circuit help
« Reply #1 on: Tue, 27 May 2014, 17:45:57 »
Since everything is on the same row you shouldn't.
Offline OldDataHands
« Reply #2 on: Tue, 27 May 2014, 22:41:54 »
that micro doesn't have support for USB, does it? (pick a micro that does...)
also, none of those diodes appear to me to serve any need.
For your purposes, configure the switch input pins as pull-up, and have the switches connect that pin to ground( or vise-versa). nothing else required.
Why is D1 present? It would be very abnormal. You should remove it.
« Reply #3 on: Wed, 28 May 2014, 07:53:56 »
Okay so since i posted this all diodes have been removed, also attiny24/44/84 will seemingly work with vusb, which i think will make it work fine. Thanks for the help though!
