Author Topic: FC660M with mx clears  (Read 1685 times)
Offline kohi
« on: Wed, 28 May 2014, 13:03:28 »
https://www.massdrop.com/buy/Leopold-FC660M-Mechanical-Keyboard-clear-switches
not sure if anyone posted this yet, but yeah - if you're looking for a relatively cheap board with clears
and theres only 40 in stock apparently...
Re: FC660M with mx clears
« Reply #1 on: Wed, 28 May 2014, 13:29:18 »
I've got one of these and it is an excellent board!
Offline Latin00032
« Reply #3 on: Wed, 28 May 2014, 15:44:21 »
Are these keys compatible with other cherry mx type key caps?
« Reply #4 on: Wed, 28 May 2014, 15:46:02 »
The space bar stabilizers are completely different and the right shift is the same size as a regular left shift.
Offline Zeal
    • Zeal Generation Inc.
« Reply #5 on: Wed, 28 May 2014, 15:46:41 »
Everything but the spacebar. Leopold has really weird spacing for the spacebar unfortunately.
Offline okwchin
« Reply #6 on: Sat, 31 May 2014, 06:24:03 »
Missed out on this. Forgot to place an order before it sold 40 units.
Oh well, I guess I never really Needed it.. Just a way to try out clear switches, and get myself another 60% board :(
