Author Topic: Bird Electronics Wood Palm Rest for Happy Hacking Pro 2  (Read 4741 times)
Offline phototristan
    • https://www.youtube.com/phototristan
« on: Thu, 29 May 2014, 09:50:49 »
Here is a review video I did showing off the Bird Electronics wood palm rest:
Not sure how to get the YouTube embed option here to work.
« Last Edit: Thu, 05 June 2014, 12:16:50 by phototristan »
Offline esoomenona
  • Gnillort?
Re: Bird Electronics Palm Rest for Happy Hacking Pro 2
« Reply #1 on: Thu, 29 May 2014, 09:55:33 »
Youtube videos can't be embedded when they're https. Drop the s and it will work. Also, you can remove those size tags.
« Reply #2 on: Thu, 29 May 2014, 12:46:07 »
Tried it, still didn't work.
Offline esoomenona
  • Gnillort?
« Reply #3 on: Thu, 29 May 2014, 12:49:07 »
Weird, because it works for me, and I just copied your link.
edit: I just quoted your post, and it seems there is a font tag in the youtube tag. I'm sure removing that might make it work properly.
« Reply #4 on: Thu, 29 May 2014, 13:00:41 »
Thanks. I edited the post and pressed the 'remove formatting' and now it seems to work.
Offline UnlikeAny
Re: Bird Electronics Wood Palm Rest for Happy Hacking Pro 2
« Reply #5 on: Fri, 06 June 2014, 06:18:56 »
I wonder if you could find a cutting board about the same size and just cut how much you need. Maybe also attach some rubber feet. It would probably not feel the same, but it would be worth a try.
Changing price tag while shipping also wouldn't be a problem (if you are that type of guy), because no worker in customs would think that it would cost so much.
Nice review from you as always. I really enjoy watching them.
« Reply #6 on: Fri, 06 June 2014, 07:55:15 »
You'd probably want to round the corners too though. The nice thing about this Bird one is the corners and edges are perfectly rounded.
