Author Topic: Poker II Windows 8.1 Driver needed?  (Read 3085 times)
Offline Fire Brand
  • Keeper of Rainbows
  • BISCUITS!
« on: Thu, 29 May 2014, 16:22:35 »
Hello I was not sure where to put this but I'm currently having a issue with my Poker II it works fine on my main system but when I try to switch it to my laptop it will not install the driver for the keyboard as the system keeps refusing saying there is none, I'm just a little baffled why I can't get it working on my laptop also just to note both systems are running windows 8.1 but one is the pro upgrade and the other is a standalone installation, if anyone could point me in the direction of some from of driver I would very much thank you.
My Youtube Channel ~
Keyboards owned
My classified thread :3
Offline tbc
Re: Poker II Windows 8.1 Driver needed?
« Reply #1 on: Thu, 29 May 2014, 16:36:31 »
did you try restarting after plugging the board in?
I don't think i've even seen a driver install for a simple board before (only sometimes for boards with macro keys)
Offline Coreda
« Reply #2 on: Thu, 29 May 2014, 16:38:13 »
Strange. Mine didn't install any driver and I'm running 8.1 Pro.
Offline Fire Brand
  • BISCUITS!
« Reply #3 on: Thu, 29 May 2014, 16:41:41 »
Yes I have tried restarting but it seems to not do anything, when I check under device manager it shows Poker II ! and states I need to install a driver as it didn't come with one and windows cannot find one, it also switches between showing as a Poker II and a Poker Pro S, but does not do this on my main computer ;/
Keyboards owned
Offline kaotikb
« Reply #4 on: Thu, 29 May 2014, 16:57:37 »
Did you try a full shutdown? By default windows 8 does a hybrid shutdown
Ducky 1087 (Green ALPS) |  CM QFR Stealth (MX Brown) | Unicomp Ultra Classic |Poker II (MX Brown)  | IBM 1391401 1991 | IBM 1391401 1989 | Ducky Shine 3 White Edition (MX Brown) | G80-3700(MX Black) | Corsair K70 (MX Brown) | Varmillo VA87MR (Gateron Red)
Pointing Devices:  Microsoft Trackball Optical (Ceramic bearings Installed)  | Sanwa MA-TB39BK (Larger Ceramic Bearings Installed) | Elecom M-XT2URBK | Kensington Slimblade | Logitech Trackman Wheel | Logitech Trackman Marble Plus
Offline Fire Brand
  • BISCUITS!
« Reply #5 on: Thu, 29 May 2014, 17:13:07 »
Yes I have I am starting to think it could be to do with the laptop though as I have just forced it into safe mode, huge pain to get it into it as well I have just noticed there was a firmware update for the poker released last year I may try that but odd how it keeps asking for a driver
Keyboards owned
Offline kaotikb
« Reply #6 on: Thu, 29 May 2014, 20:16:34 »
Another thing to try is a new usb cable, who knows maybe its defective.
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #7 on: Thu, 29 May 2014, 21:24:33 »
I was using Win8 and the poker ii was running fine. I'm getting a new laptop with win8.1 soon-ish(?).
I'll see if there's any driver probs. no guarantee I'll get it this week though.
Offline Fire Brand
  • BISCUITS!
« Reply #8 on: Fri, 30 May 2014, 03:51:14 »
Thanks everyone for giving me ideas anyway, got it sorted not honestly sure if what I did helped but after updating the firmware, rebooting into safemode removing the driver it had tried installing it reinstalled and works fine, it currently shows as a Poker II instead of the Poker Pro S as it normally shows but, its working so everything worked out thanks people :)
Keyboards owned
Offline lakiozoon
« Reply #9 on: Fri, 30 May 2014, 12:12:05 »
A question about poker 2 (i don't want to open a new thread).
Is it possible to swap/remap the fn key to caps lock?
Since i mostly game, having the fn key on right side is not practical since i want to be able to keep my hand on my mouse while still having the access to F keys.
Regards.
Offline Sagii
  • Time to bust some nails
« Reply #10 on: Fri, 30 May 2014, 12:18:48 »
Regards.
Yes, that is possible :) One of the DIP switches does that
Offline ideus
  • Björkö.
« Reply #11 on: Fri, 30 May 2014, 13:15:20 »
Regards.
What about the PN key? Could that be remapped by DIP switches?
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #12 on: Fri, 30 May 2014, 17:39:11 »
Mine shows poker ii all these while. Good to know it's working for you :)
