Author Topic: Taking apart a Keycool 84...  (Read 4518 times)
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Commercial Vendor
  • The 00verseer of Vault 77
    • Mechanical Keyboards
« on: Thu, 29 May 2014, 17:41:05 »
Does anyone know if there is a thread on here, or would anyone have any pointers on taking one apart?
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
Offline 00zeRO
Re: Taking apart a Keycool 84...
« Reply #1 on: Thu, 29 May 2014, 17:43:19 »
Nm...got it...lol
Offline Firebolt1914
  • POM Overlord
« Reply #2 on: Thu, 29 May 2014, 21:26:39 »
Even though I'm not looking for it, leave what you did/found for other people to stumble on this thread.
Offline 00zeRO
« Reply #3 on: Thu, 29 May 2014, 22:13:52 »
No problem. There are no screws, just clips that are easily popped away by twisting a small flathead screw driver. Once they all pop, it comes apart. As for the plate, it has four tabs where it slides into slots on the PCB. Desolder every switch, then move the twist the tabs to be straight, and it looks like the plate comes off. Now, I did not remove all the keycaps, so there may be a screw or two involved, but I kinda doubt it.
