Author Topic: G81 doesn't work, need help  (Read 1599 times)
Offline Jokrik
« on: Fri, 30 May 2014, 11:34:13 »
Hi,
Just recently bought a G81 from taobao , white case with dolch set, blue switches
beautiful! but thing is; other than the yellowing on the caps (which is a big disappointment)
the thing doesn't work on my pc, I used PS/2 to USB adapter
there is a switch at the back of the keyboard, when I switched it to PC mode from AT I can turn on/off all the capslock, scroll and numlock (the led is working)
but I can't input anything whatsoever
running a windows 8.1, can anyone help me here?
Re: G81 doesn't work, need help
« Reply #1 on: Fri, 30 May 2014, 11:36:12 »
U wot m8?
G81 are MY switches...
« Reply #2 on: Fri, 30 May 2014, 11:38:14 »
U wot m8?
Maybe someone stuck a dolch PCB in a white G81 case?
« Reply #3 on: Fri, 30 May 2014, 11:41:05 »
Yep, that's what they did. LAAUS definitely wouldn't have dolch :))
Offline Jokrik
« Reply #4 on: Fri, 30 May 2014, 11:50:14 »
lol, no wonder I've been wondering
My chinese isn't that good and when a friend showed me this on taobao, I was curious and bought it
now i'm stuck.. definitely blue switches, since I just cleaned the keycaps
I'm new to all these g80's world  :-X
« Last Edit: Fri, 30 May 2014, 11:54:09 by jokrik »
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #5 on: Fri, 30 May 2014, 12:07:51 »
You want it on AT actually. AT= PS/2... PC=XT. Hope you didn't fry the controller running it in wrong mode... it can happen.
« Last Edit: Fri, 30 May 2014, 12:09:24 by IvanIvanovich »
Offline Jokrik
« Reply #6 on: Fri, 30 May 2014, 19:43:18 »
It's now working out of nowhere
not sure what happened lol thx guys for the info! :)
