Author Topic: lg 25inch 2560x1080 monitor $220 (costco)  (Read 4337 times)
Offline pas008
« on: Fri, 30 May 2014, 13:04:32 »
yes I am a lurker
but thought I had to share this here
http://www.costco.com/.product.856262.html?MobileOptOut=1
Re: lg 25inch 2560x1080 monitor $220 (costco)
« Reply #1 on: Fri, 30 May 2014, 13:20:18 »
that's an odd aspect ratio
I think it'd be great in vertical mode though.
Offline esoomenona
  • Gnillort?
« Reply #2 on: Fri, 30 May 2014, 13:24:28 »
It says ultra wide: General: Dimensions (without stand): 24"W x 11"H x 1.56"D
« Reply #3 on: Fri, 30 May 2014, 16:04:03 »
If the numbers are correct, it should have 111 PPI.
The height of the screen is about the same as a:
19.8" 16:9 screen or a
18.4" 16:10 screen, or a
16.2" 4:3 screen
Offline Frenir
  • HHKB Viking
« Reply #4 on: Fri, 30 May 2014, 16:07:15 »
Im really digging this new Ultrawide fad, the monitors look very slick.
« Reply #5 on: Fri, 30 May 2014, 17:00:45 »
IMO, they are only useful vertically.
Keep in mind that I still think 5:4 is the best and have used it for many years.
« Reply #6 on: Fri, 30 May 2014, 17:20:14 »
Two 16:10 screens mounted vertically side to side?
I would get an ultrawide screen only if it was high enough and slightly curved. Curved screens make sense for single-user desktop computer use, they don't make sense for TV or cell phones.
If a screen is too wide, the sides would be weird if the screen is not curved. If a wide screen is not large enough, it is just vertically challenged, which is pitiful.
« Last Edit: Fri, 30 May 2014, 17:27:41 by Findecanor »
Offline Sniping
« Reply #7 on: Fri, 30 May 2014, 19:03:07 »
From what I saw at Costco, these monitors are super short. I wouldn't be comfortable using this.
« Reply #8 on: Fri, 30 May 2014, 22:46:03 »
I always angle the outer panel towards myself anyway, resulting in an approximation of a curve.
Offline pas008
« Reply #9 on: Sat, 31 May 2014, 03:35:52 »
not picking a fight but what does this mean, I am a surround plus 2 user, 5760x1080 with 2560x1024 above
also isnt this the closest you can get to a true cinema display?
Offline Sniping
« Reply #10 on: Sat, 31 May 2014, 04:39:25 »
As mentioned earlier, this monitor has 11" height. This is compared to around 15" height of a 23" monitor, which is why I think the monitor looks a bit squished.
I think a 27" 1440p monitor would be a better buy at around $300.
