Author Topic: banggood pbt keycap spacebar on FC660M  (Read 6557 times)
Offline kohi
« on: Fri, 30 May 2014, 14:55:41 »
does anyone know if the spacebar from the banggood keycool blank pbt keycap set will fit on the FC660M?
http://www.banggood.com/PBT-87-Blank-White-Key-Caps-For-Cherry-MX-Keyboard-p-84084.html
Offline eyesmiles
Re: banggood pbt keycap spacebar on FC660M
« Reply #1 on: Fri, 30 May 2014, 15:52:49 »
I have keycool blank POMs on my FC660M. 6R-1 is from the 87 set and the 6R-2 is from the 84 set. Both fit the 660M. Assuming they use the same molds, the spacebar should fit fine.
Offline kohi
« Reply #2 on: Fri, 30 May 2014, 15:59:30 »
thank you for the comparison :thumb:
do you have the link for the blank POM keycaps by any chance?
Offline eyesmiles
« Reply #3 on: Fri, 30 May 2014, 16:05:41 »
I think banggood either stopped carrying them or are currently out of stock. I bought one set of each awhile back. You can still find the sets on taobao iirc.
Offline ideus
  • Björkö.
« Reply #4 on: Fri, 30 May 2014, 17:56:50 »
yes it does. Shall be the KC84 set.
Offline kohi
« Reply #5 on: Fri, 30 May 2014, 18:09:28 »
the KC84 set wasn't in stock, so I ordered the KC87 set. I think the mold for the spacebar was the same (also same for the POM keycaps) so hopefully the spacebar will fit *crosses fingers*
Offline ideus
  • Björkö.
« Reply #6 on: Fri, 30 May 2014, 18:19:04 »
I hope so too. Please report back if it is the same space bar in the KC87 set.
Offline kohi
« Reply #7 on: Fri, 30 May 2014, 18:27:53 »
sure thing! ;D
Offline kohi
« Reply #8 on: Wed, 04 June 2014, 03:30:36 »
update: just got my K87 keycaps, and the spacebar fits! - for anyone who wanted to know.. lol
Offline ideus
  • Björkö.
« Reply #9 on: Wed, 04 June 2014, 07:59:55 »
Great it fits! May we know the price you paid for it?
Offline china
« Reply #10 on: Wed, 04 June 2014, 11:10:37 »
Really good to know. I'll be ordering the same set after the weekend purely for the spacebar, if it's still in stock that is!
Offline kohi
« Reply #11 on: Wed, 04 June 2014, 12:16:51 »
so it's around $18 dollars for the set, but if you choose to get it shipped from the US warehouse, you have to pay $1 more.
I chose the US warehouse option and got it delivered to me within 3 business days  - pretty fast.
The spacebar is slightly warped on the right side (as was mentioned by a lot of people who got these caps) - easy to fix though.
Offline luisbg
« Reply #12 on: Wed, 04 June 2014, 12:55:55 »
Do they have them in blank black?
Leopold FC660M - Brown mx switches - black case - white blank keys :: ErgoDox - Blue mx switches - classic case - black blank keys
Offline kohi
« Reply #13 on: Wed, 04 June 2014, 14:22:25 »
I think so. I know they also had a blank set in grey, and a pom keycap set in black - but AFAIK they're all sold out
Offline luisbg
« Reply #14 on: Wed, 04 June 2014, 14:23:34 »
Do you have a link so I can keep an eye on it and see if they get more in the future?
Offline kohi
« Reply #15 on: Wed, 04 June 2014, 14:43:33 »
I couldn't find the link to the blank black ones (I think they took it down :'()
here are the white ones if you're interested: http://www.banggood.com/PBT-87-Blank-White-Key-Caps-For-Cherry-MX-Keyboard-p-84084.html
Offline luisbg
« Reply #16 on: Wed, 04 June 2014, 15:06:50 »
Thanks! I had seen the white ones but want black ones. I have a blank key set already that is missing compatible spacebar and modifiers.
I want a white alphanumeric area and black modifiers/spacebar/rest.
Offline kohi
« Reply #17 on: Wed, 04 June 2014, 15:10:52 »
oh, which white keyset did you buy for your keyboard?
Offline luisbg
« Reply #18 on: Wed, 04 June 2014, 15:29:28 »
This: http://www.vendio.com/stores/E-sports-Gaming-equipments/item/pbt-key-caps/104-105-pbt-white-blank-key-ca/lid=19240210
Since I bought the keyboard from qtan, I thought it would be a good idea to buy they keyset in the same shipment.
