Author Topic: Logic Controls KB3000 - Need a Windows Driver?  (Read 2979 times)
« on: Fri, 30 May 2014, 16:15:20 »
I can usually resist the temptation to cart home really weird keyboards, but this behemoth intrigues me.
It is all metal (I have not opened it up, yet, at least) and is monstrously heavy. It seems clean and intact. I booted it up using the PS/2 connection, and it seems to be alive (the keys give a little chirp when depressed) but Aqua Key Test does not recognize them.
Who knows anything about these, and where I might find a driver?
I see them selling on ebay in the $200+ range, so I assume that they are currently viable, but I really want to be able to test it, whether or not I decide to sell it.
« Last Edit: Sat, 31 May 2014, 16:03:50 by fohat.digs »
"you've got to cheat like hell"
- D Trump - 2026-09-10 Dallas, Texas
"The pure products of America go crazy"
- William Carlos Williams - "For Elsie" 1942
Re: Logic Controls KB3000 - Need a Windows 7 Driver?
« Reply #1 on: Fri, 30 May 2014, 16:38:31 »
there's a good chance that one of those DIN connectors is for power. I have a large all metal keyboard (pinnacle DeKO) with almost the same connectors where one is used to power the KB. I believe it exhibited similar behavior when just PS/2 was connected.
Then again, it might need a driver. Only about 103 of the switches work with my ID innovations multimode usb adapter, the rest don't seem to send anything usable.
You can test this with a soarer and HID listen (to see what you're getting out of that PS/2 connection). This is my next plan to get all those awesome switches working.
« Reply #2 on: Fri, 30 May 2014, 17:56:46 »
This thing is monumentally Bad-Ass, but I cannot seem to find the driver. Many sites have the user manual, but where do I find a Windows driver?
With a PS/2 via Soarer I get R05 with every key press.
That is just some sort of general error, isn't it?
How do I hook up a DIN plug to give it power?
« Last Edit: Fri, 30 May 2014, 20:27:11 by fohat.digs »
Re: Logic Controls KB3000 - Need a Windows Driver?
« Reply #3 on: Sat, 31 May 2014, 21:01:08 »
Why is this so hard?
The PS/2 connection seems to be acceptable, the documentation calls it the standard. I really think that I just need a driver, but I can't seem to find one anywhere.
I would never trust those all-in-one "let us scan your hardware and tell you what drivers you need" downloads to be junk-free.
Anybody got any ideas?
Offline Grendel
- I'm game !
« Reply #5 on: Sun, 01 June 2014, 09:05:36 »
http://www.bematechus.com/kb3/
Thanks, but been there. Seems to work but at the end of the install tells you that the file is missing and contact the manufacturer.
Offline False_Dmitry_II
« Reply #6 on: Sat, 07 June 2014, 18:13:09 »
Could always connect the serial port, just to see if that does anything.
« Reply #7 on: Sat, 07 June 2014, 19:23:01 »
If I had a cable. And I am not sure that my motherboard has a connection, either.
« Reply #8 on: Thu, 03 July 2014, 16:11:56 »
Somebody make me an offer on this thing.
I feel sure that it works, every key beeps when pressed, it must be a driver problem (ie I don't have a driver).
Do I hear $40-50 shipped domestic US? It is way heavier than my F-122, but will fit in a game board box.
