Author Topic: sites that sell poker plates?  (Read 1273 times)
Offline Jixr
« on: Fri, 30 May 2014, 21:10:55 »
Hi, I saw a site awhile back but couldn't remember the name, that sold alum. poker plates.
If anyone could help me out that would be great.
Offline Razor Lotus
Re: sites that sell poker plates?
« Reply #1 on: Fri, 30 May 2014, 21:16:24 »
imsto has some.
you can also join the group buy on this forum from geekhackers.
I'm not sure if anywhere sells the original plate used in the poker though, but i'm pretty sure you can find plates that would fit the poker quite easily
Offline Jixr
« Reply #2 on: Fri, 30 May 2014, 21:19:37 »
yeah sorry, they were aftermarket ones, not original stock poker plates.
I'm wanting to see if there was a place I could buy colored ones instead of popping mine of and stripping it for paint.
Offline feizor
« Reply #3 on: Fri, 30 May 2014, 22:35:49 »
Do you have poker x or poker 2? Imsto ones do not fit poker 2 due to plate mount stabs.
