Author Topic: Has anyone ever bought from interwebtive at Ebay?  (Read 2306 times)
Offline xSketchy0
« on: Sat, 31 May 2014, 11:57:31 »
Hello, i'm looking to buy 2 reds and 2 brown switches from interwebtive at Ebay. Has anyone ever bought from them and has opinions but that person? Are there more trustful people that i can buy from @ Ebay?
Offline dantan
Re: Has anyone ever bought from interwebtive at Ebay?
« Reply #1 on: Sat, 31 May 2014, 12:09:37 »
The name sounds sketchy. Like InternetWebThief.
Offline xSketchy0
« Reply #2 on: Sat, 31 May 2014, 12:19:04 »
lel icwutudidthar but forreal tho. This is the guy http://www.ebay.com/usr/interwebtive?_trksid=p2047675.l2559
Offline Techno Trousers
  • ʘ_ಠ
« Reply #3 on: Sat, 31 May 2014, 12:21:23 »
I'd have no qualms ordering from someone with a feedback profile like that.
Offline xSketchy0
« Reply #4 on: Sat, 31 May 2014, 16:14:59 »
Ah, i was just wondering if somebody had some experience with him :p
« Reply #5 on: Sat, 31 May 2014, 16:18:01 »
2,379 positive and 7 negative feedback. Do you really need any extra feedback?
Offline xSketchy0
« Reply #6 on: Sat, 31 May 2014, 16:44:20 »
Or should i buy from WASD Keyboards?
Offline Jagriff
« Reply #7 on: Sun, 01 June 2014, 01:24:14 »
I would definitely recommend shopping around. Check out mechanicalkeyboards.com and 7bit at deskthority.net. I say this because those are very expensive for switches. If you mistrust that seller given his feedback then you'd be best to stay away from Ebay entirely.
