Author Topic: Aluminium cases for 38gt pcb+ imsto's universal 60% plate  (Read 1748 times)
Offline combataran
« on: Mon, 02 June 2014, 04:45:21 »
I have seen all of these cases for 60%s that were group buys recently and I was wondering if there were any websites out there where you could get them from? I've been looking at the FMJ Design #1, the Hammer premium, Duck Poker and Duck Mini v2. could someone explain to me what the subtle differences between these cases are, and if they would fit my pcb+plate combo?
Cherry G80-1000HFD | CM Storm Spawn | Keypuller.com - Key Caps News & Database
Offline BlueBär
Re: Aluminium cases for 38gt pcb+ imsto's universal 60% plate
« Reply #1 on: Mon, 02 June 2014, 06:47:33 »
Their designs are slightly different, possibly the anodizing methods and which aluminum they use, too. The Duck Mini V2 also has a raiser block and its PCB supports Alps.
They should all fit the standard Poker mounts (you didn't mention which PCB you use), some block the dip switches though.
As for where to get them, the classifieds are your best bet, they usually get produced just for the GBs.
Offline bazh
« Reply #2 on: Mon, 02 June 2014, 06:58:05 »
^: he mentioned 38GT in the title :D
Hammer premium case uses 7075 aluminium, which is better in quality than the 6061 of Duck Poker and Duck Mini v2, Duck Poker has copper blocks for adding weight, Duck Mini v2 has raiser to change the angle and also it has a pcb and plate came along
HHKB Pro2 white
Newbie again
Offline BlueBär
« Reply #3 on: Mon, 02 June 2014, 07:02:17 »
Whoops, my bad! The FMJ had the option for brass weights, too (I think the Duck's weights are brass, not copper).
Offline bazh
« Reply #4 on: Mon, 02 June 2014, 07:11:58 »
ah yeah, my mistake :p and also, FMJ has option to go with 7075 alu as well
HHKB Pro2 white
Newbie again
