Author Topic: [WTB] Cherry plate mount stabilizers  (Read 5925 times)
Offline argyakrivos
  • Trade Count: (0)
« on: Mon, 02 June 2014, 06:01:29 »
Hello,
I'm looking to change my current Costar stabilizers with Cherry plate mount ones.
Will be needing 2 sets (2 x 5 for each set = 10 stabilizers in total). Hopefully they will have their 2u and 6.5u metal-wires.
Cheers,
Argy
Offline MrChunky
  • Trade Count: (0)
Re: [WTB] Cherry plate mount stabilizers
« Reply #1 on: Mon, 02 June 2014, 08:29:01 »
deleted
« Last Edit: Mon, 02 June 2014, 10:34:04 by MrChunky »
  • Trade Count: (1)
« Reply #2 on: Mon, 02 June 2014, 08:31:22 »
I would try http://imsto.cn/index.php?route=product/product&path=61&product_id=55 in case you do not find someone.
Those are PCB mount, so no.. I wouldn't try that.
What board are you wanting to swap the stabilisers on? Unless it's a custom plate it probably won't support Costar and Cherry stabilisers.
Offline argyakrivos
  • Trade Count: (0)
« Reply #3 on: Mon, 02 June 2014, 08:49:22 »
I'm using a Phantom PCB -- More specifically, this one: http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=536.
Don't know if there are any revisions since the original phantom.  Correct me if I'm wrong, but I assume that the PCB I have, does not support Cherry PCB-mount stabilizers.
I have a universal plate that (should) support plate mount stabilizers (the one that fits filco, phantom, etc and allows you to remove the top housing of switches for repair).
  • Trade Count: (1)
« Reply #4 on: Mon, 02 June 2014, 08:51:22 »
Yeah, the Phantom doesn't support PCB mount ones like Chunky linked. It will support plate mount ones though. Hope you can find some.
Offline MrChunky
  • Trade Count: (0)
« Reply #5 on: Mon, 02 June 2014, 10:17:41 »
deleted
« Last Edit: Mon, 02 June 2014, 10:34:43 by MrChunky »
  • Trade Count: (1)
« Reply #6 on: Mon, 02 June 2014, 10:21:49 »
Ah, sorry for misinformation, didn't read the post too carefully. WASDkeyboards has almost all the parts you need, I emailed then about 3 weeks ago about the clips getting back in stock, and they said it should be within a month. So hopefully it will be soon. Keyboard Co still has 2 clips in stock http://www.keyboardco.com/product/2-filco-black-stabilizers.asp, shipping from UK though.
Hopefully this redeems my previous misinformation :-X, good luck.
No, the ones that WASD and KBC sell are Costar plate mount stabilisers. OP wants Cherry plate mount stabilisers.
Offline MrChunky
  • Trade Count: (0)
« Reply #7 on: Mon, 02 June 2014, 10:32:49 »
Posts deleted, I give up :blank: thanks for corrections.
Offline nuclearsandwich
  • Trade Count: (0)
« Reply #8 on: Mon, 02 June 2014, 10:35:22 »
Hello,
Cheers,
Argy
Do you have a plate that supports Cherry plate mount stabilizers rather than costar ones? The mounts look completely different.
Offline argyakrivos
  • Trade Count: (0)
« Reply #9 on: Mon, 02 June 2014, 11:10:20 »
I have this plate: http://geekhack.org/index.php?topic=36907.0
Offline blighty
  • Trade Count: (0)
« Reply #10 on: Mon, 02 June 2014, 11:19:34 »
FWIW, the plate design pictured is compatible with PCB mount Cherry stabs and plate mount Costar.  Plate mount Cherry requires a different shape hole (more is cut away).
Try pcb stabs ones anyway?
LZ ergo (MX silent red) | JER - A06 (MX silent black-red springs) | Duck Lightsaver V2 (MX red) | Duck Octagon V2 (gateron clear) (lifted pads) | Duck Orion V2 (gateron red) | TKC 1800 (gateron silent reds) | Mistel MD770 (MX red with GMK silencing clips) | Realforce R2TSLA-US4-IV | Realforce R2TLSA-US4-BK | TX 75 (gateron clear) | KBDFANS 75 ("vintage" MX blues) | Kinesis Freestyle Pro (MX red) | MS Surface Ergonomic | MS Natural Ergonomic Keyboard 4000 | Filco Majestouch 2 TKL (MX black) | Phantom (Filco case) ("vintage" MX blacks | Spr1t 75% PCB x 2 (MX black and gateron clear) | Cherry G80-1865 (MX browns with black springs)
  • Trade Count: (1)
« Reply #11 on: Mon, 02 June 2014, 11:21:34 »
They will not work because the Phantom PCB does not have holes for them to mount on.
That plate with the Phantom PCB will work with Costar or Cherry plate mount stabilisers. Nothing else.
Offline blighty
  • Trade Count: (0)
« Reply #12 on: Mon, 02 June 2014, 19:30:37 »
Ah, read fail for not noticing his using the Phantom PCB.  I had sourced my Cherry plate mounted sets from WFD when he was still posting, and I don't recall where he got them from, but I think he was bending the spacebar wires.  Good luck with mouser http://www.mouser.com/ProductDetail/Cherry-Electrical/0G990224/?qs=%2fha2pyFadui%2ff77L2%2f6q1E9TeTSTHkqalUnHyJbKl9I%3d
Offline argyakrivos
  • Trade Count: (0)
« Reply #13 on: Tue, 03 June 2014, 04:53:29 »
Yeah, that was my last resort. So technically, I can buy 10 of them (do they come with 2u wire?) and try bending 2 x 6.5u for spacebar.
Offline GeorgeK
  • Trade Count: (0)
« Reply #14 on: Tue, 03 June 2014, 04:58:35 »
I might have some spare - I'll check later.
You'd definitely need to bend a spacebar wire though as they were harvested from a wyse board that had some bizarre 10x or something spacebar.
And I'm in the UK!
Offline argyakrivos
  • Trade Count: (0)
« Reply #15 on: Tue, 03 June 2014, 17:29:42 »
And I'm in the UK!
Ah sweet! Hopefully you will find some for me :) Let me know when you have the chance to look.
Offline argyakrivos
  • Trade Count: (0)
« Reply #16 on: Thu, 05 June 2014, 04:34:02 »
Bump!  :cool:
Offline adventurepoop
  • Trade Count: (0)
  • I make keyboards, I guess.
« Reply #17 on: Thu, 05 June 2014, 09:28:39 »
I'm I'm the same boat as you, I've had no luck finding them
Offline argyakrivos
  • Trade Count: (0)
« Reply #18 on: Thu, 05 June 2014, 17:22:15 »
They seem to be hard to find :(
Offline JunkFace
  • Trade Count: (0)
« Reply #19 on: Thu, 05 June 2014, 18:58:23 »
Here ya guys go :) http://www.mouser.com/ProductDetail/CHERRY/0G990224/?qs=%2fha2pyFadujXQEK8%252b8SHJaAjoyTWqs285oZXp8X1spURK93nz3kq7w%3d%3d
My bad, didn't realize this was already mentioned.  I've got some extras (but no spacebar) if you guys for some reason don't want to buy off mouser.
« Last Edit: Thu, 05 June 2014, 19:00:14 by JunkFace »
Offline argyakrivos
  • Trade Count: (0)
« Reply #20 on: Fri, 06 June 2014, 07:18:46 »
I guess I'll probably end up going for mouser after all... Need to watch some videos on how to make that spacebar wire :P
Offline argyakrivos
  • Trade Count: (0)
« Reply #21 on: Sat, 14 June 2014, 13:07:50 »
Bump!
Offline argyakrivos
  • Trade Count: (0)
« Reply #22 on: Tue, 24 June 2014, 16:43:36 »
Bump! Anyone?  :'(
