Author Topic: Ullo - Small advice  (Read 2237 times)
Offline iceman0bc
Ullo - Small advice
« on: Mon, 02 June 2014, 13:50:55 »
Hey! Love this forum, sad I didn't find it earlier.
Quick question - I found a Vintage Dell AT101W ($30) and was thinking of buying it. Is it worth a buy? They are Black alps, but I just need a second opinion. I will only be using this keyboard for a year, after which I will construct my own ^^.
Thanks.
PS: Not sure if I am to post this here, sry admins.
Re: Ullo - Small advice
« Reply #1 on: Mon, 02 June 2014, 13:51:45 »
$30 shipped is a good price is you're in the US. A bit high but I really like them. They're pretty easy to work on and they have great keycaps. The Dell AT101W got me into Alps stuff.
Offline user 18
« Reply #2 on: Mon, 02 June 2014, 13:55:55 »
I've been warned against buying used 101Ws -- apparently the alps don't stand up to years of use very well.
If it's decently new and appears in good shape, go for it.
Avatar by ashdenej
Offline iceman0bc
« Reply #3 on: Mon, 02 June 2014, 14:29:20 »
Ya its $30 with free shipping. It looks perfect and the buyer says its working perfectly.
Thanks for the advice, gonna buy it in an hour.
« Reply #4 on: Mon, 02 June 2014, 14:30:06 »
Alps switches are easy enough to open up and clean. They do tend to degenerate poorly. Especially the AT101W.
Offline user 18
« Reply #5 on: Mon, 02 June 2014, 14:39:05 »
Where were you when I found one locally for $15?
Really regretting not getting it now :P
Avatar by ashdenej
« Reply #6 on: Mon, 02 June 2014, 14:40:14 »
Sorry mang
Offline user 18
« Reply #7 on: Mon, 02 June 2014, 14:41:28 »
Sorry mang
Don't worry about it. Now I know for next time :)
Avatar by ashdenej
