Author Topic: How would you clean your crumplers?  (Read 4481 times)
Offline frosty
  • jukebox hero
« on: Tue, 03 June 2014, 07:00:21 »
Mine is starting to smell like ****.
It's a barney rustle blanket to be exact.
Re: How would you clean your crumplers?
« Reply #1 on: Tue, 03 June 2014, 07:07:11 »
I find a nice bloat-shine adds a bit of fickleness to my crumples talbert. I recommend Maxiness brand bloat-shine for the best results.
Offline engicoder
« Reply #2 on: Tue, 03 June 2014, 09:07:17 »
It may be my American ignorance, but I have absolutely no idea what you guys are talking about.  ;D
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #3 on: Tue, 03 June 2014, 09:28:02 »
You are not alone. When I hear Crumpler, I think of this.
They make some awesome bags. I think I have 7 bags or so and a couple of wallets. :D
EDIT: UrbanDictionary is of no use either.
« Last Edit: Tue, 03 June 2014, 09:31:33 by JaccoW »
|||My other keyboards :
x
Offline frosty
  • jukebox hero
« Reply #4 on: Tue, 03 June 2014, 09:42:01 »
yes it is indeed a messenger bag. anyone has any ideas?
@noisyturtle
im confused
Offline exitfire401
  • The Force is Re/\l
« Reply #5 on: Tue, 03 June 2014, 09:44:35 »
Usually, I just put mine in the washing machine and let it air dry.
Offline platypus
  • dongerino adventures
« Reply #6 on: Tue, 03 June 2014, 09:50:14 »
Polish with sand from a certain island ( ͡° ͜ʖ ͡°)
« Reply #7 on: Tue, 03 June 2014, 10:00:22 »
HOW DO I CLEAN MY BAG?
Spot clean exterior stains with lukewarm water and mild soap, then remove any soap residue with a damp cloth. For heavy soiling, lightly wipe with a damp cloth. Always dry in the shade. Never submerge your bag in water, unless you both want to smell mouldy. And don't ever let it be dry cleaned, tumble-dried, ironed, treated with harsh chemicals and detergents or scrubbed like a hospital floor. Doing so will trash the protective coating on its fabric – or worse.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #8 on: Tue, 03 June 2014, 10:09:00 »
@noisyturtle
im confused
What SpAmRaY said. But if it stinks > LFGSS.com
- Washing machine
- Low temp
- Inside a bag or pillow case
- Zippers closed
- Low spin
- Maybe use one of those sports soaps if it really stinks
x
Offline frosty
  • jukebox hero
« Reply #9 on: Tue, 03 June 2014, 17:49:57 »
aye thanks everyone!
