Author Topic: Spherical MX typewriter doubleshots  (Read 3979 times)
« on: Wed, 04 June 2014, 09:02:02 »
I got a Sears electric typewriter yesterday. It has an awesome set of super-thick spherical doubleshots.
Does anybody recognize the switch?
If somebody really wants the typewriter and is willing to pay the shipping, I might sell, let me know, but otherwise I bought it for the keys.
Any ideas where i could get the rest of semi-matching set? The spacebar looks to be just over 9x.
« Last Edit: Wed, 04 June 2014, 09:06:13 by fohat.digs »
- Franklin Roosevelt 1933
Re: Spherical MX typewriter doubleshots
« Reply #1 on: Wed, 04 June 2014, 09:03:53 »
Did you forget to post a picture?
Edit: There they are. I thought it might be a Cherry M9 switch but I don't know for sure.
« Last Edit: Wed, 04 June 2014, 09:09:03 by CPTBadAss »
« Reply #2 on: Wed, 04 June 2014, 09:03:59 »
ninjad  >:D
but yeah show us some pics!
Offline RESPRiT
  • HHKB = ❤
« Reply #3 on: Wed, 04 June 2014, 09:40:22 »
Those caps are awesome... :D
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #4 on: Wed, 04 June 2014, 13:32:42 »
I've seen those kind of switch, but not with MX compatible slider before. Usually they have a keycap with built in slider sort of similar to Topre key. I don't know what they are called or who made them though. The spacebar switch does look similar to M9 but it is not. The housing is totally different.
« Reply #5 on: Wed, 04 June 2014, 13:41:35 »
I may be able to get another one. Send me a PM somebody.
« Reply #6 on: Wed, 04 June 2014, 21:06:20 »
Did you actually try the caps on an MX switch yet?  The stem supports look like they'll prevent the switch from depressing properly and I know someone had similar looking caps in the past where the stem was too big and didn't fit right either for the stem or in the housing.
Offline HaaTa
  • Master Kiibohd Hunter
  • Kiibohds!
    • http://kiibohd.com
« Reply #7 on: Wed, 04 June 2014, 21:11:26 »
I think this calls for some dismantling :D
PCB and switch desolder pics.
Kiibohd
ALWAYS looking for cool and interesting switches
I take requests for making keyboard converters (i.e. *old keyboard* to USB).
« Reply #8 on: Wed, 04 June 2014, 21:36:46 »
That spacebar. What the hell. How long is it?
« Reply #9 on: Wed, 04 June 2014, 21:51:59 »
Thanks for the tip.
Unfortunately, this is the case here. I carry my key puller and a Cherry cap around in the car so I can test in the field before I buy. In this case, the Cherry cap fit nicely on the stem in the store, but I did not consider the reverse.
These caps will not seat on the Cherry stems of my son's Filco.
