Author Topic: 60% with stepped caps and split r shift  (Read 3240 times)
Offline Pacifist
  • on hiatus
« on: Thu, 05 June 2014, 02:34:38 »
Does this exist? Or even just a stepped caps?
bonus points if programable and has LEDs
« Last Edit: Thu, 05 June 2014, 02:42:24 by Pacifist »
Offline cphead
Re: 60% with stepped caps and split r shift
« Reply #1 on: Thu, 05 June 2014, 02:35:27 »
Only on customs from what I've seen.  :p
Offline Oobly
« Reply #2 on: Thu, 05 June 2014, 06:40:22 »
GH60, Duck Eagle, Duck Viper (http://duck0113.tistory.com/81)
When they finally get shipped you may start to see some GH60 boards and parts in the Classifieds section. There is currently an Interest Check for the Viper and Eagle:
http://geekhack.org/index.php?topic=58074.0
The KBT Pure has a split right shift, but it's not programmable and doesn't have the stepped caps lock.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline ideus
  • Björkö.
« Reply #3 on: Thu, 05 June 2014, 08:17:33 »
You may like to check the Sprit DIY set that includes a 60% PCB with splitted right shift and it is programmable. You can install LEDS as well. The 2nd round GB is open now. I am not sure what do you mean by stepped caps.
Offline 0100010
  • Not Sure
« Reply #4 on: Thu, 05 June 2014, 08:55:08 »
Offline ideus
  • Björkö.
« Reply #5 on: Thu, 05 June 2014, 11:44:00 »
Stepped Cap Lock :
http://techkeys.us/products/center-stem-stepped-capslock
Well, I know what is that, however, I did not find a connection with a particular keyboard, as a stepped caps lock can be installed in any keyboard, as far as the cap is centered stem, or non centered according with the position of the switch in the keyboard PCB.
« Last Edit: Thu, 05 June 2014, 11:45:44 by ideus »
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #6 on: Thu, 05 June 2014, 12:30:51 »
Most stepped caps lock keys are off-center, which means that the caps lock switch has to be off-center as well.
TechKeys has some center mount replacements, as referenced in the photo above, but if you're wanting to use IMSTO, GMK, etc., you'd have to have a board that supported the off-center of the switch.
« Reply #7 on: Thu, 05 June 2014, 12:33:56 »
Offline Pacifist
  • on hiatus
« Reply #8 on: Thu, 05 June 2014, 12:35:42 »
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #9 on: Fri, 06 June 2014, 09:36:17 »
+1 for the Sprit 60% FaceW
  • Split Right Shift (1.75u right Shift and 1u FN): CHECK
  • Stepped Caps Lock with Off-Center Stem: CHECK
  • Programmable: CHECK
  • Support for in-switch LEDs: CHECK
