Author Topic: Maglev Keyboard coming to notebooks  (Read 2182 times)
Offline Kamen Rider Blade
« on: Fri, 06 June 2014, 13:19:13 »
Offline UnlikeAny
Re: Maglev Keyboard coming to notebooks
« Reply #1 on: Fri, 06 June 2014, 13:36:20 »
This is great. If laptops gets thicker, people will have more space to take a good keyboard with them.
Offline E TwentyNine
    • Some of My Keyboards
« Reply #2 on: Fri, 06 June 2014, 14:07:44 »
"Darfon says it is also able to tweak the resistance electronically, so the keys will have various degrees of pressure depending on the preferences of their customers."
Here's the patent: http://www.google.com/patents/US20130249658
If the pressure is adjustable wouldn't that imply an electromagnetic assembly?  Wonder what kind of power usage that entails.
Offline Greeeg
« Reply #3 on: Sat, 14 June 2014, 23:02:50 »
Probably less than you would think. From the looks of the patent, the switch is held in its neutral position by a permanent magnet.
There is another magnet in the frame of the switch which I assume when you press the keytop would induce an electric field in a PCB/coil below.
Some smart electronics could drive power back to increase/reduce the force you feel while pressing.
So there is no power being used when you aren't actually pressing on a key.
Offline islisis
« Reply #4 on: Tue, 17 June 2014, 15:50:30 »
with fast enough electronics, this could make a very versatile tactile switch! first in a laptop :D
« Last Edit: Tue, 17 June 2014, 15:55:39 by islisis »
« Reply #5 on: Tue, 17 June 2014, 15:53:07 »
if it's expensive, I'll try and find a dead one a year after it comes out.
« Reply #6 on: Tue, 17 June 2014, 17:52:52 »
you can try to get the replacement keyboard part through the normal channels.
« Reply #7 on: Tue, 17 June 2014, 18:04:17 »
But that's a simple, easy thing to do.
Why would I want that?
