Author Topic: Model F modders for hire?  (Read 5234 times)
Offline Pacifist
  • on hiatus
« on: Fri, 06 June 2014, 14:48:53 »
Are there any model F modders for hire here? Specifically a 122 ANSI modder
Offline AKIMbO
  • HHKBro
Re: Model F modders for hire?
« Reply #1 on: Fri, 06 June 2014, 15:48:50 »
Do it yourself. That mod is super easy...maybe 3/10 on the difficulty scale.  I know several ghers who've done the mod successfully (including myself). We can walk you through all the steps.
| KBD75 (box reds)
Offline vivalarevolución
« Reply #2 on: Fri, 06 June 2014, 16:09:10 »
I'll do it for you.  Just got done cleaning, painting, and modding mine in various ways and I have all the tools.
But I also recommend that you do it yourself.
« Reply #3 on: Fri, 06 June 2014, 16:34:35 »
Good to know.
What would be an 8.5/10?
PS - I always thoroughly clean every single part, sand and paint everything metal and/or rusty, and install sound padding, etc, plus, at least half the time, cut a new mat. Is that included in the 3/10?
- D Trump 2026-10-24
Offline AKIMbO
  • HHKBro
« Reply #4 on: Fri, 06 June 2014, 16:36:01 »
Good to know.
Desoldering an alps board without ruining a single switch? But seriously, anything involving smd soldering or delicate alps pcbs.
| KBD75 (box reds)
« Reply #5 on: Fri, 06 June 2014, 16:55:37 »
Oh, that. Yes, I have a few dead PCBs that I butchered and a bowl of mangled switches.
I was thinking in terms of hours and sweat.
Offline newchemicals
« Reply #6 on: Fri, 06 June 2014, 17:22:52 »
If I ever get a model F I would probably want some help modding it.
« Reply #7 on: Fri, 06 June 2014, 17:38:37 »
I would rate my F122 mod project a 9001/10.
It's been in pieces for over a year, I've tried fixing it at least seven different times to no avail. SMD soldering is quite easy for me, but this F122 is ridiculous.
Offline jwaz
  • * based mod
  • #geekhack on freenode
« Reply #8 on: Fri, 06 June 2014, 17:43:03 »
yeh, I'm really good at teh sik m0dz, just send it right over ;)
Offline sleepy916
« Reply #9 on: Fri, 06 June 2014, 18:22:42 »
It took me a few months to finish everything except the teensy because I moved in between. Putting it back together was the hardest part. But now it's sitting in a box.  :confused:
« Reply #10 on: Fri, 06 June 2014, 18:45:59 »
A staggering difference of opinions, as always.
Clearly, you should hire prdlm2009 to do it.
« Reply #11 on: Fri, 06 June 2014, 20:27:20 »
How's the mat?
Putting it together isn't the issue with clamps, time and patience. Fabricating a new mat has involved many tries and failures. I wonder if just sending rubber to a lasercutter is the best option.
« Reply #12 on: Fri, 06 June 2014, 20:54:50 »
Good to know.
That's only a toughie if they bent those damn legs over before soldering them.  I want to go back in time and slap a cracka for doing that.
« Reply #13 on: Fri, 06 June 2014, 21:11:43 »
it was pretty common, especially on ICs. It kept everything together when soldering and assembly.
WYSE did it as well.
The interesting part of model Fs is that depending on condition and what needs to be done, the repair and restoration might be easier or more difficult.
I think this is part of the disparity in opinion of the difficulty.
Offline jacobolus
« Reply #14 on: Fri, 06 June 2014, 21:24:08 »
Nah, this isn’t that difficult, it just takes practice. After desoldering about 6 of them, I now no longer damage any switches or lift any pads. (Also, what counts as “ruining”? Usually for me the damage was just the little plastic clips breaking off, which isn’t too serious usually.)
« Reply #15 on: Fri, 06 June 2014, 21:28:39 »
For me it's breaking the tips off the legs.  I never lifted a single pad, but those legs were too easy to break.
Offline jacobolus
« Reply #16 on: Fri, 06 June 2014, 22:10:16 »
I’ve only ever snapped off one Alps lead... I desoldered a Cherry MX board and snapped off several though. (First, the MX switches have flimsier leads, and second, lead-free solder is awful.)
If the leads are bent over and stuck down, what I do is, for every bent lead on the board: (a) use the soldapullt as usual pulling most of the solder out of the hole, (b) apply heat and pull up on the lead with a little metal dental pick [these are super useful general-purpose tools], until it comes free of the pad, (c) unbend the lead using some snipe-nosed pliers. Then after that, I take the PCB off, and only then try to push any switches out of the plate, making sure to push down the little plastic “wings” so they don’t break.
« Last Edit: Fri, 06 June 2014, 22:14:32 by jacobolus »
Offline jacobolus
« Reply #17 on: Fri, 06 June 2014, 22:11:19 »
If you just let the modder keep the board at the end, I’m sure you’ll have plenty of takers! :p
Otherwise, why not try to do it yourself?
Offline sleepy916
« Reply #18 on: Fri, 06 June 2014, 22:26:19 »
How's the mat?
I had to make a new mat, the old was sticking to the plate and crumbling before my eyes. Making a new mat was not hard, just took time. The set of punch tools I bought were not the best so it took a good smack each time to get a clean cut through the new rubber mat.
Offline mougrim
« Reply #19 on: Fri, 06 June 2014, 22:54:47 »
Hmm, and how thick new rubber mat should be?
IBM AT Model F, Vortexgear Race 3, AEKII (Alps Cream Damped), Metoo Zero (modded to Kailh Box Navy)
Offline sleepy916
« Reply #20 on: Fri, 06 June 2014, 23:01:18 »
 I ordered this one, it is 1/16" thick.
http://www.mcmaster.com/#8647k102/=sarjxd
Offline Techno Trousers
  • ʘ_ಠ
« Reply #21 on: Sat, 07 June 2014, 02:13:05 »
I've used that as well, and it worked out great. It's not so thick that it prevents you from getting the plates back together, but still keeps everything snug when it's reassembled.
Offline mougrim
« Reply #22 on: Sat, 07 June 2014, 02:57:36 »
Thanks! It could be useful if/when I'll get F-122.
« Reply #23 on: Sat, 07 June 2014, 16:27:24 »
I would like to know what you have been attempting to do with your F 122.  I was able to take this:
67297-0
and turn it into this:
67299-167303-2
67301-3
« Last Edit: Sat, 07 June 2014, 16:43:57 by prdlm2009 »
« Reply #24 on: Sat, 07 June 2014, 16:42:25 »
Nice work! That one was worse than any of the 10+ that I have seen and you cleaned it up well.
« Reply #25 on: Sat, 07 June 2014, 16:44:31 »
The key ingredient was a boatload of elbow grease.
« Reply #26 on: Sat, 07 June 2014, 16:59:27 »
Once you get the courage to take the thing completely apart, you can be really aggressive. Then it goes much faster and you can get an immaculate finished product.
That is probably a big part of the reason that I just dis-assemble everything, all the way, if I possibly can, because it makes cleaning/sanding/painting  * so *  much more satisfying.
Offline mougrim
« Reply #27 on: Sun, 08 June 2014, 04:21:18 »
What a big table you have...
