Author Topic: 34% keyboard almost done :D  (Read 4366 times)
Offline adventurepoop
  • I make keyboards, I guess.
« on: Fri, 06 June 2014, 15:55:16 »
All I have left to do is wire the teensy, which I'm waiting for in the mail. I'm so excited :o
Offline HPE1000
  • Keycap Paparazzo
Re: 34% keyboard almost done :D
« Reply #1 on: Fri, 06 June 2014, 15:56:37 »
Wow, what is the keymap on that? lol
Offline user 18
« Reply #2 on: Fri, 06 June 2014, 16:01:59 »
Very pretty caps. I'm also interested in the keymap, and of course, the switch type.
Avatar by ashdenej
« Reply #3 on: Fri, 06 June 2014, 16:03:45 »
Keymap http://ne0.cc/laygenV2/#1MAjK
I'm using blue switches. I need to get a dsa space bar though >.> this one is weird
Offline HPE1000
  • Keycap Paparazzo
« Reply #4 on: Fri, 06 June 2014, 16:06:30 »
Seems pretty well laid out given how many keys you have to work with, there can be fn layers on it I assume? I would probably put , on the same key as .
Offline user 18
« Reply #5 on: Fri, 06 June 2014, 16:20:10 »
I think I recall seeing that map somewhere before.
I agree with HPE, personally I would do ,/. instead of ./>
Two del keys?
Avatar by ashdenej
Offline daftendire
« Reply #6 on: Fri, 06 June 2014, 16:28:28 »
This thing is beautiful. :eek:
« Reply #7 on: Fri, 06 June 2014, 16:36:31 »
Two del keys?
second del is an accident :/ whoops
Offline MTManiac
« Reply #8 on: Fri, 06 June 2014, 16:41:17 »
wow... that is very nice!
makes me want to make one as a started project soldering switches
only thing I'd change is map Ctrl to the bottom left where Fn is and remap the Fn to the bottom Del
nice work, very clean
Offline UnlikeAny
« Reply #9 on: Fri, 06 June 2014, 17:07:49 »
This keyboard looks so cute. If you could use numbers by pressing function key, this could be fully usable. With that size, you could take it anywhere.
Offline HotKillerZzz
  • Ammesia
« Reply #10 on: Tue, 08 July 2014, 09:37:29 »
love it, would love it for my study table. Maybe i shall make one  :-*
  • Ammesia
« Reply #11 on: Tue, 08 July 2014, 09:38:47 »
Btw how does the casing look like? Could we have more pictures around and under it?
Offline deltuhhh
« Reply #12 on: Tue, 08 July 2014, 11:10:32 »
34%?? Man that's REALLY small. I love the keycaps btw
Offline Oobly
« Reply #13 on: Wed, 09 July 2014, 04:16:10 »
Very nice little board. I assume it's made from a plate from another board? Which firmware are you planning to use or will you write your own?
You might want to add some stabilisers to the spacebar.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
