Author Topic: Where can i buy costar stabilizers?  (Read 3172 times)
Offline Bakgrund
« on: Sat, 07 June 2014, 13:48:26 »
Hey, I'm looking to buy some costar stabilizers, they were surprisingly easy to break and now I'm sitting here with a bad spacebar.
Wasdkeyboards has been out of stock for weeks, any other good places that sell them?
Quickfire Rapid    Quickfire Rapid
Mx Browns          Mx Reds
Ducky thick PBT   Stock caps
Re: Where can i buy costar stabilizers?
« Reply #2 on: Sun, 08 June 2014, 03:05:00 »
+1 for mechanicalkeyboards, I have got mine from them each time.
Offline Dr Xav
« Reply #3 on: Sun, 08 June 2014, 03:31:54 »
I have the same question but for PCB mounted cherry stabs.  I can't seem to find them anywhere.
« Reply #4 on: Sun, 08 June 2014, 03:36:26 »
http://www.gonskeyboardworks.com/stabilizers/18-pcb-mount-stabilizers.html
Only one I could find on short notice.  OOS though.
Offline Dr Xav
« Reply #5 on: Sun, 08 June 2014, 04:30:30 »
Thanks, I have been using Gons quite a bit ;) Highly recommanded btw :D he was out of stock for my last order and I was thinking to get a bit more that just one set.
« Reply #6 on: Mon, 09 June 2014, 02:11:43 »
Also: http://imsto.cn/index.php?route=product/product&path=61&product_id=55
