Author Topic: Noppoo Choc S PRO 104 LED - Need help  (Read 3347 times)
Offline jboyce92
« on: Sun, 08 June 2014, 09:58:06 »
http://www.yoybuy.com/en/show/13790635744/?s=t
Hello, I am very interested in purchasing this keyboard, however I do not understand the Chinese language variations, etc (black shaft, blue axis, etc). I want this keyboard with a black frame, red LED and brown switches (tea axis). If someone knows if this variation exists for this board, that would be great. Its a great price on this site also, so if anyone can help me find this version of it that would be really appreciated. I currently own a Noppoo Choc Mini with Brown Switches and I would love to have this full size with LED lighting, and particularly red to match my tower lighting.
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Noppoo Choc S PRO 104 LED - Need help
« Reply #1 on: Sun, 08 June 2014, 10:15:42 »
It does not appear available at that shop, but this shop does have the combination you are looking for and is reputable http://www.vendio.com/stores/E-sports-Gaming-equipments/item/shop-mechanical-keyboard-by-br/noppoo-pro-mechanical-keyboard/lid=26543616
Offline jboyce92
« Reply #2 on: Sun, 08 June 2014, 10:19:36 »
Thanks for the reply, this is exactly what I am after. I'm curious now, on that link I included is their any form of a brown switch version as an option that you can tell? For example, do you know what "CHOC white tea axis" means?
« Reply #3 on: Sun, 08 June 2014, 10:24:28 »
I would guess it means white case body, brown switch. As far as I know the white version doesn't come in backlight.
Offline jboyce92
« Reply #4 on: Sun, 08 June 2014, 11:00:28 »
I see, thanks again for the help. My last question is, do you know of any other keyboards that have the media keys on lets Q, W, E, and A, S, D, like the Noppoo Choc mini as well as this full size one? Its just a preference thing on mine and I haven't seen any others that are like this yet, usually they are on the F1-F12 keys or the number keys. Referring particularly to this:
