Author Topic: Blank colored thick PBT caps?  (Read 2956 times)
Offline Broduce
« on: Sun, 08 June 2014, 22:27:13 »
Is there anywhere to buy thick PBT singles of various colors? I know some artisan crafters have sold blanks before, so I'm guessing they aren't readily available anywhere?
Offline Pacifist
  • on hiatus
Re: Blank colored thick PBT caps?
« Reply #1 on: Sun, 08 June 2014, 22:30:37 »
Imsto blanks
Offline Broduce
« Reply #2 on: Sun, 08 June 2014, 23:22:00 »
Imsto blanks
On the IMSTO website? I'm not seeing where to order colored blanks
Offline fleimi
« Reply #3 on: Mon, 09 June 2014, 06:11:21 »
First time poster here (on Geekhack) and first time posting on a Colemak layout, it's taking a ****ing lifetime... Anyway, only place I know to buy PBTs is SP, but I don't think they sell singles, worth checking though.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #4 on: Mon, 09 June 2014, 10:32:53 »
I think only the light blue color is readily available still maybe. imsto have had blank RGB set and some red 1x1 key in the past, but otherwise there is not much in the way of colorful PBT key in Cherry thick. You could always try your hand at dye them yourself. It's not that difficult to get a good result, though many of RIT color seem to have had formula change and do not work as well as they used to or at all now in some case.
Offline Quardah
    • DeliTech
« Reply #5 on: Mon, 09 June 2014, 11:00:27 »
Hey buddy, you seem to be new. Welcome to geekhack!
Here is something that might help you in your mighty quest for holy keycaps, it's our "ALL KEYCAPS SITE LIST" thread that we built in here. It contains the sites we know that sells keycaps.
Here : http://geekhack.org/index.php?topic=45672.0
Hope this help!
Cheers!
See my blog here : https://delitech.live
Poker II - Brown MX
Ducky One II TKL - Silver MX
TEX Shinobi - Clear MX
Offline davkol
  •  Post Editing Timeout
« Reply #6 on: Mon, 09 June 2014, 13:02:11 »
PBT SA from SP's inventory should fit the bill. Not cheap though.
Offline Broduce
« Reply #7 on: Mon, 09 June 2014, 20:11:26 »
Thanks, not sure why I glossed over this in my search. $1 each isn't too bad.
Offline davkol
« Reply #8 on: Tue, 10 June 2014, 01:39:00 »
An ErgoDox set costs about as much as an IMSTO's full set, but I'd have to add not exactly cheap shipping and tax. T_T
Offline Broduce
« Reply #9 on: Tue, 10 June 2014, 19:34:15 »
Ordered a few 1x PBT blanks from SP late last night and they shipped this morning! Can't wait
