Author Topic: 45g Springs with MX Clears  (Read 2626 times)
Offline esko997
  • Linux Lover
« on: Mon, 09 June 2014, 21:32:19 »
Anyone ever done this before? Is there a name for this spring/switch combo? Just did it to my ErgoDox and it feels pretty cool so far -- definitely enjoying it.
Daily Drivers:  Unicomp Customizer (BS -- Linux Layout) | Vortex Race 3 (Clears)
Other Boards: CM Quickfire Stealth (Greens) | Poker II (Blues) | PLU-ML 87 (Ergo Clears)  | JD40 (Browns) | Leopold FC660C (Topre) | IBM Model M | ErgoDox (Clears) | Sentraq s60x DIY (Blacks) | Anne Pro 2 (Blues) | Cherry G80-11900 (Blacks) | Kira (99 Key) (Hako True)
Offline cphead
Re: 45g Springs with MX Clears
« Reply #1 on: Mon, 09 June 2014, 21:35:03 »
I did that on my Filco. Super light. Very nice.
« Reply #2 on: Mon, 09 June 2014, 21:35:58 »
I like to call them...45g MX Clears :P
Make sure to lube them. I've tried other 45g Clear boards before and the modifiers would stick. They would press down and not return.
Offline fknraiden
« Reply #3 on: Mon, 09 June 2014, 21:38:56 »
They seems to be sticky
Offline Pacifist
  • on hiatus
« Reply #4 on: Mon, 09 June 2014, 21:40:07 »
add thin lube
Offline Oobly
« Reply #5 on: Tue, 10 June 2014, 07:35:48 »
Korean 45g springs or springs from Blues / Reds / Browns? I like to use 62g Korean springs, lighter ones have a tendency to stick unless lubed since the bump is so large.
Also works best with worn-in switches. New ones will have a little more friction.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline iloveucla
« Reply #6 on: Sat, 14 June 2014, 02:29:07 »
Do we still able to buy those korean spring from any US store/sellers?  :p
Offline Oobly
« Reply #7 on: Mon, 16 June 2014, 05:15:45 »
Originative has 45g and 55g springs in stock.... http://www.originativeco.com/collections/accessories/products/springs
I think there was a GB running for gold plated springs, too.. http://geekhack.org/index.php?topic=55888.0
