Author Topic: Poker II iso vs ansi keycaps  (Read 4574 times)
Offline UnlikeAny
« on: Tue, 10 June 2014, 10:02:01 »
Have you noticed that Poker II ISO keycaps looks like crap compared to ANSI version?
http://kkcdn-static.kaskus.co.id/images/2013/05/10/566184_20130510102335.jpg
http://ecx.images-amazon.com/images/I/71YHH6wxD2L._SL1500_.jpg
I want to get this keyboard, but the only place where I find one has only ISO layout. It's funny how it comes with 2 long green shift keys - there isn't one who would fit on the left side. It also looks so asymmetrical...
Too bad there aren't a lot of 60% keyboards to choose from.
Offline MAR82
  • Keyboard Addict
Re: Poker II iso vs ansi keycaps
« Reply #1 on: Tue, 10 June 2014, 10:24:20 »
Your first link doesn't work (403 - Forbidden)
But in the second link it has ABS backlit keycaps, maybe the first link has PBT keycaps?
Offline UnlikeAny
« Reply #2 on: Tue, 10 June 2014, 10:43:07 »
Give that link another try. It has gave me the same error before, but after that it worked.
Maybe the second link is a wrong picture. I'm not even sure anymore. Amazon is always messed up.
Here is where I found this ISO keyboard.
http://www.amazon.co.uk/gp/product/B00GERJZJK/ref=ox_sc_act_title_4?ie=UTF8&psc=1&smid=A35N9T5Y3WBHX9
Offline MAR82
  • Keyboard Addict
« Reply #3 on: Tue, 10 June 2014, 10:59:59 »
I still can't get the link to work, if it looks like this http://imagehost.vendio.com/a/35122654/aview/POKER2-1.jpg then it's PBT and not backlit ABS like in the second link
If they are both Backlit ABS then I have no idea  ;)
Offline Oobly
« Reply #4 on: Tue, 10 June 2014, 11:05:23 »
I had the same problem. I ended up getting a KBT Pure Limited ANSI layout with Browns, since I couldn't find a Poker2 with ANSI layout from a european vendor and didn't want the hassle of customs.
Apparently munch (in Sweden) is selling a Poker X (PCB mounted and not programmable, but standard ANSI layout): http://geekhack.org/index.php?topic=59333.0
Otherwise it looks like you'll have to order a Poker 2 from outside EU.
And I agree, ISO Poker 2 looks lame somehow, much prefer ANSI layout for a number of reasons.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
