Advanced search
bounce or buckle?
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
NEW USERS, READ
THIS!
Home
Watched
Unread
Notifications
IRC
Wiki
Search
Spy
Login
Register
geekhack
geekhack Community
Keyboards
G80-3700 has switched itself to mode 3 and won't switch back
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: G80-3700 has switched itself to mode 3 and won't switch back (Read 1329 times)
GeorgeK
Thread Starter
on:
Tue, 10 June 2014, 11:22:42 »
In case you're unsure as to what Mode 3 is it means that it'll only type !@#$% instead of 12345 (
http://deskthority.net/wiki/Cherry_G80-3700
It's connected to my PC through an adapter but even when I plug it straight into a PS2 port on another computer it still doesn't work (I'm following the instructions on the deskthority wiki page I linked to - Num Lock, 1, Enter)
Has anyone come across this before? How do you fix it?
Thanks in advance
GK
Logged
Black Filco TKL - Stickered, Lubed Reds || Poker w/Plate, Alu Case - Stickered, Lubed 65g Ergo-Clears || Cherry G80-3700 w/SS Plate - Lubed 65g Ergo-Clears
GeorgeK
Thread Starter
Re: G80-3700 has switched itself to mode 3 and won't switch back
Reply #1 on:
Wed, 11 June 2014, 11:01:39 »
Managed to sort it
I wasn't holding down both Num Lock and 1 before pressing enter... Just in case anyone else needs this in the future - hold down both Num Lock and 1, then press and release Enter before releasing the other two.
Edit: This was also not in a PS2 port but through one of mkawa's magic PS2-USB converters
Logged
Daniel Beardsmore
RIP
Reply #2 on:
Wed, 11 June 2014, 16:48:56 »
From the wiki, I would assume:
Press Num Lock
Press 1
Release 1
Press Enter
Release Enter
Release Num Lock
From what you're saying, it is:
Press Num Lock
Press 1
Press Enter
Release Enter
Release 1
Release Num Lock
Is that correct?
Logged
Bore Awards
GeorgeK
Thread Starter
Reply #3 on:
Thu, 12 June 2014, 03:52:29 »
Pretty much yeah - you need to have both Num Lock and 1 held down before pressing enter
That's what was confusing me...
Logged
Daniel Beardsmore
RIP
Reply #4 on:
Sat, 14 June 2014, 09:00:09 »
I've verified this with the manual and updated the wiki page accordingly.
Logged
Bore Awards
Print
Pages: [
1
Go Up
« previous
next »
geekhack
geekhack Community
Keyboards
