Author Topic: Ergodex DX1 input system  (Read 6817 times)
Offline xyzzy
« on: Fri, 08 May 2009, 13:17:02 »
http://search.ebay.com/200339242714
Interesting item, it looks like bad software/driver support is its weakest point.
IBM Model F62 (Ellipse's) • PFU HHKB Pro Type S Hybrid • PFU HHKB Pro • Leopold FC660C • IBM Model M SSK 1391472 • IBM Model M SSK UNI04C6 • IBM Model M 1391405 (x4) • Cherry MX 1800 Compact (blue Cherry) • Cherry MX 11900 Touchboard (brown Cherry) • Dell AT102W (black Alps) • Apple Extended Keyboard II (cream Alps) • Acer 6312-TA (black Acer) • Unikey KWD-601 (white Cherry)
Offline huha
« Reply #1 on: Fri, 08 May 2009, 14:43:42 »
That is one monstrous ferrite core on the cable.
-huha
Unicomp Endurapro 105 (blank keycaps, BS) // Cherry G80-3000LSCDE-2 (blues, modded to green MX) // Cherry G80-3000LAMDE-0 (blacks, 2x) // Cherry G80-11900LTMDE-0 (blacks, 2x) // Compaq G80-11801 (browns) // Epson Q203A (Fujitsu Peerless) // IBM Model M2 (BS) // Boscom AS400 Terminal Emulator (OEM\'d Unicomp, BS, 2x) // Dell AT102DW (black Alps) // Mechanical Touch (chinese BS) Acer 6312-KW (Acer mechanics on membrane) // Cherry G84-4100 (ML) // Cherry G80-1000HAD (NKRO, blacks)
Offline itlnstln
« Reply #2 on: Mon, 11 May 2009, 07:08:13 »
Quote from: ripster;89946
That looks like my teenagers corn snake after he eats a mouse!
I had to re-read that a few times.  It's too early in the morning to decipher "corn snake."  I had one of those a few days ago after a Cinco de Drinko BBQ.  I don't think that's what ripster was referring to, though.
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #3 on: Mon, 11 May 2009, 10:27:55 »
Quote from: itlnstln;90234
His son obviously has one of these critters, whose preferred diet are small rodents such as mice. As we all know, snakes usually are able to swallow amazingly large things, then gaining a bit of a funny appearance not quite unlike a cable with a ferrite core.
Admittedly ripster's sentence was lacking in clarity.
Offline itlnstln
« Reply #4 on: Mon, 11 May 2009, 10:37:57 »
OK.  I am more aware of them as the (red) rat snake.
Offline pmyshkin
« Reply #5 on: Tue, 12 May 2009, 00:20:14 »
How exactly does that thing work?
Offline itlnstln
« Reply #6 on: Tue, 12 May 2009, 06:53:54 »
Quote from: pmyshkin;90371
Snakes?  Well, they tend to move by using speciaized scales that act like "feet" to propel the snake as it slithers.  Some snakes use poison to immobilize/kill their prey before consuming.  Others use a constriction method to asphyxiate their prey.  All snakes consume their food whole and can dislocate their jaws to consume larger prey.
Oh, you meant the Ergodex.  Get on topic, pmyshkin.  We're talking about snakes, here.
Offline o2dazone
« Reply #7 on: Tue, 12 May 2009, 09:52:37 »
ffffhahaha
Offline itlnstln
« Reply #8 on: Tue, 12 May 2009, 09:56:25 »
Quote from: o2dazone;90430
ffffhahaha
Offline pmyshkin
« Reply #9 on: Tue, 12 May 2009, 14:14:04 »
Quote from: itlnstln;90395
That's it. I've had it with these motherf**king snakes on this motherf**king thread.
Offline itlnstln
« Reply #10 on: Tue, 12 May 2009, 14:42:37 »
Quote from: ripster;90469
I was waiting for that one.
Anyone notice the autocensor doesn't seem to pick up s*** anymore? Try it.
- Ripster
Fail.
Offline iMav
  • geekhack creator/founder
« Reply #11 on: Tue, 12 May 2009, 14:56:37 »
No need.  I think I've got the message across that this is a family-friendly community and unnecessary vulgarity is not needed.
I turned off the censor.  :)
Offline o2dazone
« Reply #12 on: Tue, 12 May 2009, 15:05:27 »
Offline watduzhkstand4
« Reply #13 on: Sat, 16 May 2009, 10:23:46 »
I've seen this around but I just don't think it is very convenient. If you get intense with the game then the keys will move, no?
KEYBOARDS
Cherry Blue *Filco Tenkeyless w/ blank keys* w/ red ESC key thanks to Megarat
Cherry Red Noppoo Choc Mini
IBM Model M 1391401 12/15/88
Siig Minitouch w/ White Alps
SOLD
HHKB Pro 2 white w/ blank keys red ESC key and blank WASD keys
HHKB L-2
Cherry Brown Compaq mx11800
Dell AT101W
Cherry Red Leopold 104-key Otaku FC500RR/ABN
