Author Topic: Aluminum TKL LED Keyboard  (Read 5727 times)
Offline jardinski
« on: Thu, 12 June 2014, 02:48:27 »
Hello Everyone! I recently have been getting into mechanical keyboards, I started with a steel series 6g then moved to a poker 2. Anyway, I wanted to pick up another keyboard and can not find a keyboard that has everything I want in it.  I am looking for a Tenkeyless sized board (or really anything with arrow keys but not a numpad), that is led back-lit, and has an aluminum case. I know this will end up costing quite a bit, but at the moment I cant find anything. I like the look of the ducky shine 3 TKL and code TKL, but neither have any aluminum case options as far as I can tell. Filcos have aluminum aftermarket cases but no LED's. I was wondering if anyone knew of any keyboards that are purchasable that meet all these criteria? Thanks so much for the help!
Offline tbc
Re: Aluminum TKL LED Keyboard
« Reply #1 on: Thu, 12 June 2014, 02:56:06 »
gonskeyboardworks.com has them....but they are very pricey (although still priced appropriately to the competition)
Offline kohi
« Reply #2 on: Thu, 12 June 2014, 03:03:50 »
haha breaking out the korean customs :eek:
they might have aluminum cases for the ducky, but I haven't seen any specific for it
I found a video of a vortex al case:
by whitefiredragon, and I believe he used his 2013 year of dragon ducky tkl with it.
so if you don't mind the two holes for filco indicator light - you can prob use that if you can find one in stock..
otherwise you might have to look around - there may be some custom aluminum cases - but ofc, those are prob much more expensive.
Offline jardinski
« Reply #3 on: Thu, 12 June 2014, 03:08:17 »
TBC,
Thanks for the quick reply! Those are very nice and very expensive. That is exactly what I was looking for though. I was considering spending around 300 for a board but 460 sounds a bit pricey. If anyone knows of any around 300 please let me know. If not I guess ill have to compromise or save up a bit longer. Thanks again!
Offline tbc
« Reply #4 on: Thu, 12 June 2014, 03:12:32 »
you can assemble it yourself for a little bit cheaper (assuming you have an iron already).  gon will happily sell you all of the individual parts.
Offline jardinski
« Reply #5 on: Thu, 12 June 2014, 03:18:15 »
Cool, that seems like it could be a good option. Is there a lot of risk involved in breaking the keyboard if you were to file off the edges like he suggests in the video?
« Last Edit: Thu, 12 June 2014, 03:20:28 by jardinski »
Offline kohi
« Reply #6 on: Thu, 12 June 2014, 03:27:07 »
I wouldn't think so, since you'd technically only be filing the metal plate
but it really depends, because I don't know how the dimension of the 2013 tkl compares to the ducky shine 3 tkl
they will most likely be the same, but just to be sure - it might be a good idea to ask someone else who knows;;
Offline minho
  • i'm kind of back
« Reply #7 on: Thu, 12 June 2014, 08:09:28 »
Pretty sure that case is very difficult to find right now :(
« Reply #8 on: Thu, 12 June 2014, 08:10:53 »
It's not a full LED board but I really like the KMAC TKL boards.
Offline jardinski
« Reply #9 on: Thu, 12 June 2014, 21:02:34 »
I saw this keyboard but I couldn't find anywhere selling one. Are these still being sold?
Also thanks everyone for the great suggestions!
« Reply #10 on: Thu, 12 June 2014, 21:21:42 »
kbdlab (kbdmod?) has them but you have to get a proxy.
Offline jardinski
« Reply #11 on: Thu, 12 June 2014, 21:32:25 »
I know this isn't what i was originally asking, but if I decided to simply cut out the LED factor, and only looked for a tenkeyless board with an aluminum case, would i have more options?
Offline Pacifist
  • on hiatus
« Reply #12 on: Thu, 12 June 2014, 21:33:46 »
phantom in a vortex case
Offline jardinski
« Reply #13 on: Thu, 12 June 2014, 21:36:57 »
in the video hojunski posted, the guy tried that and said it didn't fit.
Offline sakai4eva
« Reply #14 on: Thu, 12 June 2014, 22:11:47 »
Not exactly TKL, but you can try checking out the Lightsaver thread to see if anyone's willing to let go.
Offline Grendel
« Reply #15 on: Thu, 12 June 2014, 23:45:33 »
You could get a TEX case for your Poker II until a TKL comes around ;)
- I'm game !
Offline minho
  • i'm kind of back
« Reply #16 on: Fri, 13 June 2014, 00:00:30 »
Vortex case should fit the Phantom as Phantom was designed to fit Filco and Vortex was designed with Filco in mind too...
However, Phantom is not backlit compatible too my knowledge.
Offline Pacifist
  • on hiatus
« Reply #17 on: Fri, 13 June 2014, 00:02:08 »
he wanted to see what non backlit options he had
Offline minho
  • i'm kind of back
« Reply #18 on: Fri, 13 June 2014, 00:05:19 »
Doh, my bad.
On a related note, are there any backlit keyboards that fit into the Vortex case? I searched and only a modified Shine 2 was mentioned.
Offline Oobly
« Reply #19 on: Fri, 13 June 2014, 01:41:49 »
Sherry lists these on his site, the Black Filco option seems to be available: http://www.originativeco.com/collections/keyboards/products/filco-realforce-aluminum-case
But I'm not sure if he actually has any to sell... Send him a PM if interested. They look like this: http://kbdmod.com/web/detailimg/Maje_DB.jpg
IMHO, a Ducky Shine in that case would be rather nice  :)
MK also sell an aluminium case, but it seems they're out of stock: http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=280
You may be able to find a KMAC2 in the classifieds or for sale elsewhere. Not sure about backlighting on that, though.
Then there's Gon. Not cheap, but you get what you pay for.
The MK case is the cheapest option, so may be best to send them an email asking if and when they'll get stocks again.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline kohi
« Reply #20 on: Fri, 13 June 2014, 03:40:50 »
I think jdcarpe is selling the vortex aluminum tkl case on classifieds (last item)
http://geekhack.org/index.php?topic=59475.0
if you're still looking...
Offline jardinski
« Reply #21 on: Sat, 14 June 2014, 03:30:35 »
Thanks everyone. Looks like I missed the jdcarpe sale of the aluminum case. I think I'm going to pick up a shine 3 then get one of those aluminum cases if I can find it somewhere.
Offline minho
  • i'm kind of back
« Reply #22 on: Sat, 14 June 2014, 04:28:10 »
Are you sure the shine will fit?
« Reply #23 on: Sat, 14 June 2014, 06:16:02 »
I can assure you that it won't.
OP, don't do that, there are no ALU cases that fit the shine 3.
Offline minho
  • i'm kind of back
« Reply #24 on: Sat, 14 June 2014, 09:05:34 »
That's what I thought, only ducky I heard of in any ALU case was a nodded shine 2 :(
Offline jardinski
« Reply #25 on: Sat, 14 June 2014, 10:31:10 »
Ok never mind then, and thanks for the great advice. I guess I'm back to searching. There really isn't many aluminum TKL boards out there.
Offline minho
  • i'm kind of back
« Reply #26 on: Sat, 14 June 2014, 10:37:48 »
BTW, about the KMAC not being sold... I tried to order one off kbdmod.com but was unsuccessful (couldn't register) so I emailed the email they have in the contacts about international shipping. The person replied a few days later that they do support international shipping, so if you contact them, you might be able to arrange something.
