Author Topic: 122-key Model F - 6110347  (Read 2643 times)
Offline 1391406
« on: Fri, 13 June 2014, 01:09:32 »
This one has a starting bid of $99. It's missing a couple of F-keycaps.
Offline vivalarevolución
Re: 122-key Model F - 6110347
« Reply #1 on: Fri, 13 June 2014, 13:05:51 »
Looks to be in decent condition.  Certainly seen worse.
Offline didjamatic
« Reply #2 on: Fri, 13 June 2014, 14:28:52 »
Too bad the missing caps are ones you can only get on another model F and not from an M.
« Reply #3 on: Fri, 13 June 2014, 14:34:04 »
You can order a full replacement set of caps from Unicomp, but they won't be exactly the same.
You order item "CPSET" and in the comments put "1389001 Pearl/Pebble"
Offline 1391406
« Reply #4 on: Fri, 13 June 2014, 19:19:30 »
They really won't be exactly the same, but it's no big deal. I'd end up replacing them with original Model M F-row key caps anyway.
