Author Topic: [Video] Clipping Cherry Stabilizers  (Read 4834 times)
Offline BlueBär
« on: Fri, 13 June 2014, 03:20:00 »
Just a small video that shows how to clip Cherry stabilizers. I know Litster has a nice video of this already but I also show how to get them off your PCB, how to disassemble them and some lube spots :thumb:
As always, any feedback is appreciated and all questions are welcome!
Offline feizor
Re: [Video] Clipping Cherry Stabilizers
« Reply #1 on: Fri, 13 June 2014, 03:35:18 »
Is this only for PCB mount stabilizers? Or does it apply to plate as well? Do I need to resolder every single switch to get to the stabilizers on a plate mount?
Offline BlueBär
« Reply #2 on: Fri, 13 June 2014, 04:04:15 »
Yes this applies to Cherry plate mounted stailizers as well (I think I even say that in the video somewhere). You only need to desolder the switch in the center of the two stabilizer bases if your keyboard has a plate.
Offline qwack
« Reply #3 on: Fri, 13 June 2014, 06:36:28 »
Great video, very thorough and informative, thanks!
Pure Pro w/MX Red - [review]
Offline feizor
« Reply #4 on: Fri, 13 June 2014, 06:41:57 »
Thanks, I'll give it a go!
