Author Topic: O rings for mx blues  (Read 1934 times)
Offline Raddam
« on: Fri, 13 June 2014, 14:57:26 »
What is the best o ring you can get for cherry mx blues that have the least amount of travel reduction, reduce the bottoming out sound and don't make the keys feel mushy? I found one type but I don't know if is is the best option or not? http://www.amazon.com/Cherry-Rubber-O-Ring-Switch-Dampeners/dp/B00AZQ3966/ref=pd_cp_pc_0
Thanks in Advanced!
Re: O rings for mx blues
« Reply #1 on: Fri, 13 June 2014, 15:33:26 »
Yeah. Those are the thinnest ones I know of.
Offline Grendel
« Reply #2 on: Fri, 13 June 2014, 15:52:32 »
These are at least as thin.
- I'm game !
« Reply #3 on: Fri, 13 June 2014, 21:36:13 »
O-rings on MX blues will dampen the sounds from bottoming out, but will not affect the clickyness at all.
Many people find the high-pitched clicking more annoying than the bottoming out sounds, which is more like a thump thump thump.
Offline Raddam
« Reply #4 on: Sat, 14 June 2014, 00:00:07 »
I love the clicking noise I just want to get rid of the bottoming out noise  :)
« Reply #5 on: Sat, 14 June 2014, 00:48:40 »
Then O-rings are your thing!
