Author Topic: HP Mini USB Keyboard Tenkeyless (Membrane Sheet)  (Read 7306 times)
Offline dante
« on: Fri, 13 June 2014, 20:04:44 »
Before finding this on Ebay the only membrane sheet tenkeyless I was aware of is the IBM RT3200 SpaceSaver II and read of an obscure Fujitsu available only in Japan.
It feels like a rubber dome, maybe albeit ever so slightly shorter travel.  All the hotkeys worked plug-in-play with Windows 7.  Average 2-6KRO depending on combination.  If you'd like me to test a specific combo let me know.
Re: HP Mini USB Keyboard Tenkeyless (Membrane Sheet)
« Reply #1 on: Sat, 14 June 2014, 06:57:45 »
This means that it's 2KRO. When determining key rollover, it's always the minimum number of pressed keys that fail - 1, or the "worst case" sucessful combination.
The most number of keys you can hold down is something like <number of rows in the matrix> + <number of columns in the matrix> -1 or something like that.
yeah, it's odd that there's less TKL keyboards that aren't mechs. I don't know why they never caught on.
Offline sami77
« Reply #2 on: Thu, 06 August 2015, 01:08:27 »
hey ! sorry for pump up this
i'm looking for Gaming Membrane TKL  with 6KRO at least  everywhere in the keyboard
Can you test  these combinations  (Cursor keys + SPACE BAR.. Q,W,E,A,S,D )
(I, J,K,L) + (Q,W,E,A,S,D)
Offline dante
« Reply #3 on: Fri, 07 August 2015, 20:13:36 »
sami77: If you can deal with a big ass enter key and tiny backspace you can get a Korean I-Rocks K20.
Offline sami77
« Reply #4 on: Sat, 29 August 2015, 09:48:40 »
i got it yesterday ! it's amazing but again yea that tiny BS is trouble some
wonders what those KOREAN keys doing ? (Beside Left and Right  SpaceBar) ?
Offline dante
« Reply #5 on: Sat, 29 August 2015, 10:30:21 »
I think if you install the (windows) Korean language pack those keys become useful in someway to the language.
The 1 unit backspace is overblown ... use it for a while and you won't even notice it.  If it really bothers you remap the capslock to backspace for more ergo benefits.
Offline BrewCaps
« Reply #6 on: Sun, 30 August 2015, 19:48:50 »
Eww...rubber dome
