Author Topic: Does the Das III get annoying?  (Read 3063 times)
Offline fuzzybaffy
« on: Sat, 09 May 2009, 22:08:58 »
I'm currently considering the Das III, as I love the clicking action, but I'm afraid I won't like it for extended periods of time.
Anyone with a Das III have bad/positive experiences with the clicking? And how would it compare to, let's say, a Happy Hacking Keyboard Pro 2 (cause that's the other keyboard I'm considering as well)?
Offline ozar
« Reply #1 on: Sat, 09 May 2009, 22:17:32 »
I get tired of the high-pitched clicks associated with blue cherries after a few days.  Some people get addicted to the sound I guess.  The HHKB Pro 2 is quite a bit quieter than the Das board.
Offline Rajagra
« Reply #2 on: Sat, 09 May 2009, 22:30:36 »
LOL What a coincidence...
I love the sound of the DAS, but as it's 4AM I was worrying about the sound carrying to other rooms (it doesn't tbh, but you can't help wondering).
So I just grabbed my old Logitech Dinovo. I've never used it properly as I hate laptop-type keys. But I have to say it makes a refreshing change. It's nice to have the option of something quiet with a soft, lazy feel.
(I've even configured the special buttons on the Dinovo. That's the kiss of death, it's bound to die within days.) :laugh:
Offline Rajagra
« Reply #3 on: Sat, 09 May 2009, 23:14:23 »
It's like putting cards in the spokes of bicycle wheels to make a clackity sound - the faster you go, the more satisfying it sounds!
Offline fuzzybaffy
« Reply #4 on: Sat, 09 May 2009, 23:27:03 »
Quote from: ripster;90084
Anyway, the two keyboards in general are like night and day so maybe you could tell us a little more what you plan on using it for and the keyboards you've tried before.
- Ripster
Well, I have to say I'm a little conflicted. I honestly love the soft, mushy feel of some of the rubber-dome keyboards, but I also love the sound of a solid click. So maybe something in between? Something soft, while having a bit of tactility?
Offline ozar
« Reply #5 on: Sat, 09 May 2009, 23:30:35 »
Quote from: fuzzybaffy;90097
Based on that, I'd say you'd probably like the HHKB Pro 2 better, but if I'm wrong, it could be a costly mistake because you can purchase a couple of Das boards for the price of one HHKB Pro 2.
Offline pmyshkin
« Reply #6 on: Sun, 10 May 2009, 01:46:36 »
For me, the sound and tactile feedback of the blue cherries has the same satisfaction as chewing on ice for some odd reason. I think my brain would tune it out as background noise before I get tired of it.
Offline wellington1869
« Reply #7 on: Sun, 10 May 2009, 03:15:56 »
Quote from: pmyshkin;90105
I like chewing on ice...
For me the cherries werent chunky enough... i had to go back to the M to be satisfied. The M's chunka-chunka makes me thing of industrial machinery (and hence a sense of production and productivity I guess). Steam locomotives, factories, mills... etc.
It also helps tune out background noise as pmyshkin says. A kind of white noise that helps you focus, and the more you type and produce, the more steady the noise is, and so you produce even more - there's a "virtuous circle" of positive feedback you can get on to.
When the noise stops I actually miss it ;)
I think the trick is to find a noise that you like. Not all noises are the same, obviously, and your personal taste matters a lot. For instance, I didnt like the white alps noise after a while (too high pitched, and the attack/decay wave was too abrupt, I thought). I like the lower-toned, deeper chunka's of the M. (Made even deeper on my board with a light spot of silicon grease on the springs).
What that means is, while you can get a rough idea of what you might like, ultimately there's really no substitute for acquiring each board you're interested in and trying it out in person. "Its a process". Nothing like a test drive.  You can always re-sell the ones you dont want.
« Last Edit: Sun, 10 May 2009, 03:20:36 by wellington1869 »
using: ms 7000/Das 3
« Reply #8 on: Sun, 10 May 2009, 03:23:06 »
or you could try the software route ;)
http://geekhack.org/showwiki.php?t=4664
Offline itlnstln
« Reply #9 on: Mon, 11 May 2009, 07:32:23 »
You could look for the Silicon Graphics version of the AT101W.  The Alps sliders in that version have rubber dampers that soften the bottoming out of the switches.  You can also find them in AEKII.
