Author Topic: Best O rings for noise reduction?  (Read 2511 times)
Offline DuckNorris
« on: Tue, 17 June 2014, 17:53:08 »
Hey guys,
  Now that I got my QFR Stealth I was in the market for some o rings to reduce the noise of my keyboard to be able to take it to work. I got lost looking through amazon at so many. I just care for sound reduction, which are the best at reducing sound? And I link would be appreciated XD . Thank you for your help!
Re: Best O rings for noise reduction?
« Reply #1 on: Tue, 17 June 2014, 17:56:46 »
o rings of any sort can help out a lot with bottom out noise
But they won't do anything about the distinctive "top out" noise that cherry keyboards get.
Depending on your co workers this may or may not be acceptable. I know in my workplace, a cherry brown KB was too loud (I don't bottom out) so I had to bring in a 30g topre.
Offline ideus
  • Björkö.
« Reply #2 on: Tue, 17 June 2014, 18:57:15 »
Browns were too loud? Where do you work? In a library?  :p
Offline Quardah
    • DeliTech
« Reply #3 on: Wed, 18 June 2014, 07:55:25 »
Indeed, brown are pretty silent. Only thing i can tell is quieter are Matias switches.
See my blog here : https://delitech.live
Poker II - Brown MX
Ducky One II TKL - Silver MX
TEX Shinobi - Clear MX
« Reply #4 on: Wed, 18 June 2014, 08:57:21 »
It's that "top out" noise. Matias is dampened on both ends (top and bottom out) so it's much quieter.
30g topre is quieter as well.
My co-worker explained it to me once that he was just very picky. He types pretty loudly on his rubberdome.
Anyway, it's the top out noise that's loudest on cherry MX, and there's no good way to quiet it.
To actually answer the OP's question, o-rings or "soft landing pads" will help a lot if you bottom out. WASDkeyboards sells some that are nice, but you can certainly go elsewhere.
Offline Oobly
« Reply #5 on: Wed, 18 June 2014, 10:16:13 »
Ahem, latex mod, ahem....
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline scaz
« Reply #6 on: Wed, 18 June 2014, 14:01:01 »
Massdrop has o rings deal going on right now.  https://www.massdrop.com/buy/max-keyboard-o-rings
Offline DuckNorris
« Reply #7 on: Thu, 19 June 2014, 13:53:32 »
Thanks for the link I will look into it.
Offline Justintoxicated
« Reply #8 on: Thu, 19 June 2014, 14:38:29 »
will those orings work on topre? Leopold FC660C specifically?
